Found My Prob With V20 Spoon help ???
  • Aor5000uk
    • Feb 2021
    • 18
    v17 working perfectly
    upgraded to new v20
    but has to go back to v17 because i was getting errors when i was trying to rip cds.
    thought i'd try v20 today and test a few things one by one.
    FOUND The issue
    i can rip cd with upto 7 images attached [I scan the books, covers etc]
    BUT once i add 8 or more images thats when it errors out.
    never had this issue with v17
    Mr.Spoon could you please have a look at fixing this please
    • 44047
    Re: Found My Prob With V20 Spoon help ???
    Windows or macOS? ripping to which format?
    • Aor5000uk
      • Feb 2021
      • 18
      My apologies
      Windows 11
        • 44047
        Encoding to which format?
        • Aor5000uk
          • Feb 2021
          • 18
          Flac and Wav
          • Aor5000uk
            • Feb 2021
            • 18
            This is an older error I posted on the forem b4. I'm assuming the error is the same now.
            Error ripping to FLAC, 'Track 1' to 'D:\* Music\FLAC\Wig Wam - 2010 Non Stop Rock'N'Roll (FLAC)\01 Wig Wam - Do Ya Wanna Taste It.flac'
            Destination file: D:\* Music\FLAC\Wig Wam - 2010 Non Stop Rock'N'Roll (FLAC)\01 Wig Wam - Do Ya Wanna Taste It._1 [clEncoder_FLAC::BeginConversion]
            WFX: Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0 [clEncoder_FLAC::BeginConversion]
            Error initializing FLAC encoder (FLAC__STREAM_ENCODER_INIT_STATUS_ENCODER_ERROR,FL AC__STREAM_ENCODER_FRAMING_ERROR). [clEncoder_FLAC::BeginConversion]
              • 44047
              Both wave and flac cannot have more than 7 album arts? what is the exact error message for wave?
              • Aor5000uk
                • Feb 2021
                • 18
                V17 I've added 18 art at one point.
                I'll give you the error later when I get home, before I'll uninstall v20 and go back to V17
                • GBrown
                  • Oct 2009
                  • 287
                  What are the combined file sizes of these images? From the spec for ID3v2 - "Since each frame can be 16MB and the entire tag can be 256MB you'll probably never again be in the same situation as when you tried to write a useful comment in the old ID3 being limited to 30 characters." FLAC I believe also has a similar limitation for the header.
                  • Aor5000uk
                    • Feb 2021
                    • 18
Name:	v17 18 pictures.jpg
ID:	294651Click image for larger version
Name:	v17 73mb in totoal picturea.jpg
ID:	294652Click image for larger version
Name:	v17 complete sucess 16 pictures attached.jpg
ID:	294653Click image for larger version
Name:	v20 same cd same pictures.jpg
ID:	294654Click image for larger version
Name:	v20 same cd same size 73mg.jpg
                    • Aor5000uk
                      • Feb 2021
                      • 18
Name:	v20 error log 1.jpg
ID:	294656Click image for larger version
Name:	v20 error log 2.jpg
                      and here are the 2 page error log
                      • GBrown
                        • Oct 2009
                        • 287
                        I guess that answer the question. You are trying to store 73MB of pictures into a frame that only supports 16MB.
                        • Aor5000uk
                          • Feb 2021
                          • 18
                          Thanks I'll wait for spoon to reply
                          As stated V17 handles that size ... So V20 should
                            • 44047
                            It is likely this issue, flac will have been updated and restrictions placed on the actual library we use.
                            • Aor5000uk
                              • Feb 2021
                              • 18
                              right
                              so thats why V17 works with flac
                              will this get updated or fixed in the future ?
                              or should i stick with V17 and right off the cost of V20
                              thanks for your help Spoon
