How to reselect an external drive located on another computer?
  • jhstn58
    • Jan 2023
    • 32
    #46
    Re: How to reselect an external drive located on another computer?
    • jhstn58
      • Jan 2023
      • 32
      #47
      I’m not assured what you are asking for, so I have copied everything in my Path.
      JHSTN58
      • jhstn58
        • Jan 2023
        • 32
        #48
        I am not assured of what you are asking for, but I have included everything in my path.
        JHSTN58
          • 44054
          #49
          Your naming string is invalid, click 'Set' (next to naming) then choose 'Default Naming' then click OK.
          • jhstn58
            • Jan 2023
            • 32
            #50
            Spoon -
            Change what to default naming?
            JHSTN58
              • 44054
              #51
              Naming
              • jhstn58
                • Jan 2023
                • 32
                #52
                Please let me load some pictures:
                I&*8217;ve already made the changes each of you who had a comment (thank you for your patience). I need to know how to get this to achieve the result shown in the last picture. One picture showing me what the entire thread should look like. Obviously, I don&*8217;t get it yet.
                JHStn58
                  • 4015
                  #53
                  Originally posted by jhstn58
                  I have ripped thousands of cd&*8217;s and did not run into this.
                  Of the thousands of CDs you have ripped, how many were actually ripped successfully with CD Ripper, given that your Naming string syntax is invalid?
                  This thread gets more bizarre and confuses me more and more, with every post.
                  Firstly, you have ignored/failed to answer several of the questions posted throughout this thread, which makes it difficult to provide you with help.
                  Secondly, did you read (and understand), the CD Ripper help on Path and Naming, as suggested (with a link to the help page) in post no. 41?
                  Thirdly, to reset Naming to the default:
                  Launch CD Ripper and click the Set button next to the Naming drop-down.
                  The Naming window should now be visible, showing your invalid Naming string.
                  Next, click the Default Naming button followed by the OK button.
                  • jhstn58
                    • Jan 2023
                    • 32
                    #54
                    Mville-
                    I have revised the naming convention per my instructions in here, though I have followed the naming conventions set forth in the Path and Naming. I don&*8217;t have the benefits of your knowledge, so I&*8217;m not sure what happened. What I&*8217;m trying to do is to create the location of what the posts said previously, namely that I want to create in the iTunes music, the [shared] music to the band (I.e, the Beatles), followed by the naming of the album (also, the Beatles) and the name of the album contents, and then followed by the name of the individual tracks. I don&*8217;t know what happened to this format so (unless I went into the naming and changed the contents, unbeknownst to me or to the other person), I&*8217;m at a loss to the naming of the path.
                    Jhstn58
                      • 4015
                      #55
                      On your windows PC, open File Explorer.
                      Paste the following into the Address Bar and press Enter on your keyboard:
                      \\JIM-MAC-MINI\E Drive\Music\iTunes Media\Music
                      This should open the Music folder on your apple PC. If it doesn't, then you don't have network access to the folder, if it does, then continue.
                      Launch CD Ripper and delete the contents of the Path text box.
                      Paste the following into the Path text box:
                      Then, click the Set button next to the Naming drop-down to open the Naming window.
                      Finally, insert a Beatles CD into your optical drive and click the Rip button.
                      Please post the outcome, include any messages that appear.
                      • jhstn58
                        • Jan 2023
                        • 32
                        #56
                        That worked! So if I am to track the lists of the tracts (without the name of the Tract Number) by the name of the tract, what do I do?
                        JHStn58
                          • 4015
                          #57
                          Click the Set button next to the Naming drop-down to open the Naming window.
                          Next, in the Dynamic Naming box, replace:
                          [track] [artist] - [title]
                          with:
                          [artist] - [title]
                          Finally, click the OK button.
                          • jhstn58
                            • Jan 2023
                            • 32
                            #58
                            JHSTN58
