Installation instructions for double rip with CD Ripper
  • RJamesBoy
    • Aug 2022
    Have had trouble setting up CD Ripper to rip MP3 an FLAC simultaneously with each going to separate directories. Somewhere I saw that the two destinations have to be set up in two different locations? Many thanks, RJB
    • 6189
    Re: Installation instructions for double rip with CD Ripper
    In CD Ripper, you should rip to [multi encoder], then in the lower section in the middle, click on the "encoder" tab, and add each encoder (mp3 and FLAC). In each encoder addition, there is a place to setup settings for each encoder, including dynamic naming that will tell it where to place the files after ripping.
    • RJamesBoy
      • Aug 2022
      Many thanks garym, this is the piece of info I was missing. RJB
