Speed and log like eac and customize installation
  • Drugo
    • Mar 2022
    • 66
    Hi
    I have tried the trial version and i'm very impressed ,superb superb tool !
    May I ask few questions
    1)
    dBpoweramp cd ripper does rip the track on memory while is reading the cd , and encode them?
    seeing i have seeing the tracks ripped and seeing i have select multiple encoders ,dbpoweramp cd ripper does keep ripping the other tracks
    2)
    I was used to rip with EAC , to obtain a log like eac with pregaps and other flags like cd tags and Compact Disc subcode , have I to select cue single image plugins and under ripper i have to select secure and enable log
    but seeing dbpoweramp does use accurate rip , could be done enabled even in burst mode or?
    3) is there a drive to buy for dbpoweramp ?
    i have read the list , many are interanl laptop drivers
    are the asus external drive good for ripping (even are slow) ?
    in these days it's hard to find external pc dvd drives, most are external dvd drive for pc and laptop
    4) could be possible customize the installation , i don't like the right mouse context menu shell under windows , (not sure if it's present under mac=
    by the way really amazing tool , have used for 2 days and it's not cheap but really great
    thanks
    • 46143
    Re: Speed and log like eac and customize installation
    1) Yes
    2) subcodes etc are not shown in the log, sorry.
    3) better spend your money on two different cheaper drives and let accuraterip verify
    4)right click can be disabled from Control Centre
    • Drugo
      • Mar 2022
      • 66
      1) Yes
      hi
      about external drives i have found only Asus and 2 Verbatim (Verbatim 43886) , i think they are even in the list of accurate list
      I suspect that Hitachi LG GP96Y or ASUS ZenDrive U9M (i have read good review about them) are inside all LG with different firmware and again i guess they are not present in the accurate rip
      for 4) control centre do you mean dBConfig ?
        • 46143
        Yes dbconfig
        • Drugo
          • Mar 2022
          • 66
          Yes dbconfig
          hi
          but is it so hard to release a cue plugin for mac?
          and is possbile to update the aac encoder under high sierra or mojave without updated the operation system?
          thanks
            • 46143
            Cue is not currently supported on macOS, and I am not certain it could be, as it requires subcodes to be read from CD.
            The latest versions are compatible with Sierra, updating dBpoweramp would update the fdk encoder.
            • Drugo
              • Mar 2022
              • 66
              Hi
              about the AAC encoder , I mean the itunes/quicktime encoder , in windows it can be done with qaac
              but under maocos ,is there a way to update it or have I to update mojave ?
              thanks
                • 46143
                It is built into the OS so only updates from Apple will update.
