Possible to delete and reset AccurateRip Settings on OSX?
  • kevlar
    • Nov 2022
    I am using OSX and I think I may have messed up the AccurateRip settings for my drive. I switched drives today and I think I didn't let it update/reset the Accuraterip settings.
    It is a ASUS - SDRW-08D2S-U (USB Drive). Under the offset database it is listed as [Purged]. In the settings it is set to "0".
    Is there a way to delete the settings and make accurate rip reinitialize for the drive?
    Re: Possible to delete and reset AccurateRip Settings on OSX?
    On OSX it will only use the value in the database, the drive is purged because it has a non-constant offset.
