Pre-Emphasis does not show in Track Technical column
  • Pizza
    • May 2022
    • 8
    I have a CD, target Beatles Abbey Road from Japan, but Pre-Emphasis is not showing in the track technical column. I want to apply De-Emphasis in the rip but preference says CD tracks need to be marked with Pre-Emphasis. If I rip it as is, will De-Emphasis be applied or not? If not, what should I do? Thank you for any help.
    • 4021
    Re: Pre-Emphasis does not show in Track Technical column
    What is the catalog no. of your CD?
    • Pizza
      • May 2022
      • 8
      Thank you.
      • Pizza
        • May 2022
        • 8
        Number on the side of the case is cp35-3016
          • 4021
          Discogs and the Pre-Emphasis user database are reporting CP35-3016 as being mastered with pre-emphasis.
          You could rip the CD without de-emphasis and use foobar2000 with the de-emphasis component installed, as your audio player.
          • Pizza
            • May 2022
            • 8
            Thank you for your replies mville. I tried what simbun suggested. I haven't played it yet and not sure if I did it right. I was aware that this CD was mastered with pre-emphasis but a bit disappointed that the software couldn't recognize it though I realize it was how the CD itself was mastered. It did recognize it on another CD that I ripped this morning that I didn't know had pre-emphasis, so that's pretty cool!
            Thank you mville and simbun.
            • JayNYC
              • Feb 2008
              • 58
              @spoon any chance you would add SubCode Pre-Emphasis detection to CD Ripper? Would make everyone's life a lot easier. The type of Pre-Emphasis could be reported in the Track Technical column, right? And the DSP de-emphasis would then 'kick in' reliably in any type of Pre-Emphasis scenario....
