DVD-Rom reads meta-info system writes empty WAV's without accessing the optical drive
  • Jimi Bondi
    • Mar 2022
    Hello,
    I´m new here and say thanks for all helper-people.
    I use the licensed Ripper/Batch Ripper. I had previously installed the single license on a computer, but it always crashed due to CPU heat. So reinstalled on a new motherboard. Audio CD is recognized, fetches covers and writes wave data that cannot be listened to. It is striking that the CD-Rom reads metas, but is not claimed when writing the Wav's. PS: However, I have already worked successfully with the reinstallation. The rip process is about x160 and completed in a few seconds.
    What is wrong?
    Thanks for your help.
    Win10
    Asrock J4105 8GB
    and many Audio-CD-Roms
    Re: DVD-Rom reads meta-info system writes empty WAV's without accessing the optical d
    Set the ripping method to burst, does that work?
    • Jimi Bondi
      • Mar 2022
      Hallo Spoon,
      thanky you for yor tip. I've tried all modes. Don´t work with "secure or burst". I have a feeling this has something to do with licensing. But I only use the reg. Version.
      best regards
        All versions can rip, try:
        If still no go then restart windows in safemode with networking and see if rips then.
        • Jimi Bondi
          • Mar 2022
          Hello,
          thank you very much for the tip. I will test it tomorrow and report the result here
          best regards
          Herbert
          • Jimi Bondi
            • Mar 2022
            Hello,
            I tested the recommendation. Unfortunately, I had no success. I therefore reinstalled win10 and CD Ripper/batch. However, I still updated win10. Perhaps this is the fault. If I find this I will contact you again.
            Thanks and best regards
            Herbert
