Musicbrinz manual metadata search problem (Beethoven box set)
  • ramonesfan
    • May 2018
    • 11
    Hi Spoon,
    I am trying to use manual metadata search to import track listings for the following release:
    It's a 118-disc Beethoven box set, and when I look at the Musicbrainz webpage, it appears that each individual disc is properly tagged.
    When I use the manual metadata lookup (17.5, Mac), however, the results do not appear to match what I can see through the web client.
    Can you take a look at this listing to see if dbPoweramp is parsing it properly? Thank you!
    Re: Musicbrinz manual metadata search problem (Beethoven box set)
    It does look messed up, we will add onto our list to look at for the next update.
    • ramonesfan
      • May 2018
      • 11
      Re: Musicbrainz manual metadata search problem (Beethoven box set)
      Thank you!
