How to rip directly to external hard drive using iMac
  • jartsinc
    • Jun 2021
    Silly question, but I just got dBpower Amp and cannot figure out how to rip directly to the external drive without going through iTunes. It keeps ripping to iTunes even when I select no......
    Re: How to rip directly to external hard drive using iMac
    What do you mean ripping to iTunes? you mean iTunes appears and starts ripping?
    • jartsinc
      • Jun 2021
      I'm sure it's user error since I'm 60 years old and no longer "up to speed". I am trying to rip directly to a Samsung SSD external hard drive but I can't seem to do so. And it keeps asking if I want to add to iTunes library and I say no. But that's where it ends up and nothing on the external drive. I've had this project on hold forever and finally decided to move forward so very frustrating. I used to be in the music business and I've got about 3000 CDs I need to rip and let go. I've looked at Youtube videos and it seems very straight forward. FYI- I am using an older iMac, not my new one since the old one still has a built in drive but that shouldn't be related to this issue.
        iTunes will ask this, select no and close iTunes, then run dBpoweramp CD Ripper. In the lower left corner you can choose where it writes to.
        • GBrown
          • Oct 2009
          • 431
          iTunes only has options to Show CD, Play CD, or a few options to Import CD. But there is no option to ignore that would be preferred. Usually when I am ripping I close iTunes to avoid having it poke its head up. Otherwise I leave it running in the background.
          • jartsinc
            • Jun 2021
            OK, thank you both for your suggestions. I'll give it another try since I took the day off work and it's going to be 117 degrees here today. Good day to be inside. Will let you know how it goes. Thanks again. It has so be something really simple....
            • jartsinc
              • Jun 2021
              I think I'm good to go. I just have to force iTunes to quit each time when it rears it's ugly head and then it lets me rip to external. Thanks again for helping out a tech-challenged old man!!
                • 1932
                Isn't there another way to tell the operationg system not to start iTunes when a CD is inserted into the drive?
                • GBrown
                  • Oct 2009
                  • 431
                  Not sure on Mac, but I know for the Win version there is not if iTunes is already open. But if it is not running, it does not interfere.
