The 'Audio CD - Remove Gaps' DSP does not function in dBpoweramp CD Ripper R17.3.
  • jason.mulree
    • Apr 2021
    When using the 'Audio CD - Remove Gaps' DSP does not function in dBpoweramp CD Ripper R17.3, the information logs shows 'Gapless information is missing, ensure this DSP effect is used with CD Ripper (R14 or later)'. I have the 'Gap (Pre-Track)' and 'Index Positions' columns visible.
    This issue does not appear to exist when reverting to dBpoweramp R16.6 using identical settings, unfortunately I could not download earlier dBpoweramp R17.x to test.
    I have tested on multiple computers which have yielded similar behaviour.
    Re: The 'Audio CD - Remove Gaps' DSP does not function in dBpoweramp CD Ripper R17.3.
    Noted, will test.
    • Aqm Five-Tree
      • May 2021
      I've confirmed in 17.4 (Mac) the gaps are not being removed. CDs with gaps have identical time length with and without Remove Gaps enabled, file size the same, etc. Ripping only to one encoder.
        • 1685
        Thanks for the bug report.
        Indeed some of the functionality got lost in transition to R17.
        Addressed in the latest beta version-
