DSP - Hidden Track Silence Removal
  • Thg6276
    • Aug 2008
    • 187
    Bonjour,
    By the past, it was mentionned in the log file when this DSP was used.
    For example :
    Information ripping to FLAC, 'Track 12' to 'D:\Ma musique\Nirvana\Nevermind\12 Something In The Way.flac'
    Audio CD - Hidden Track Silence Removal: Deleting Silence From: 00:03:50.500 to 00:13:51.000
    It doesn't exists anymore ?
    Thanks in advance
    Re: DSP - Hidden Track Silence Removal
    Using multi encoder?
    • Thg6276
      • Aug 2008
      • 187
      No
      • Thg6276
        • Aug 2008
        • 187
        Ripped with DBP Release 17.2
        Flac Level 8
        DSP ued :
        Hidden Track Removal
        And
        Silence Track Deletion
        But nothing is indicaed on the log file as before ...
        Strange ...
          CD Ripper >> options button >> cd ripper options >> secure settings
          at the end of the list you need Report contents: Complete
          as a test set the detection threshold to 2 ms, it should find lots of silence to remove and report.
          • Thg6276
            • Aug 2008
            • 187
            Thanks Sppon
            It is OK now
            What is the dafault value, please ?
            I have -54db (0.2%)
            Where : file:///C:/Program%20Files/dBpoweramp/Help/DMC/dsp.htm*Audio_CD_-_Hidden_Track_Silence_Removal
            It is mentionned : -45db (0.6%)
            What is the best one, and what is the difference ?
              -54 I think is default.
