Normal Audio CD to rip in higher resolution?
  • Apple-Fan
    • Feb 2015
    • 35
    Dear All,
    I am quite new and preparing to rip my full CD library.
    From reading in this forum and other support sites, I understand as a general rule, that most (ist not all?) standard Audio CDs are produced in 44.1 kHz / 16 bit.
    Now I am using ROON as Media Player and many different Sonos speakers in the house; Sonos supports since mid of last year also FLAC/ALAC with 24 bit and up to 48 kHz.
    My question is now, does it make sense to convert my CDs in this higher resolution and is this possible at all?
    Thank you and have a good start into the new year,
    Christian
    Re: Normal Audio CD to rip in higher resolution?
    It IS possible, but makes no sense as you will NOT get higher resolution than the original source i.e. 16-bit, 44.1kHz.
    • Apple-Fan
      • Feb 2015
      • 35
      Thank you for the quick reply.
      But then I need to re-ask again: if I will not get any higher resolution as the source can deliver (which is for almost every Audio CDs 44,1, 16-bit), for which reason is is technically possible? is there any use case I am not aware of? Thank you!
        ALL red-book audio CDs (CDDA) are 44.1 kHz, 16-bit.
        It is technically possible to change the bit rate and sampling rate when ripping CDDA in CD Ripper, by using DSPs.
        Users may have a requirement for higher (or lower) resolution audio files, maybe for testing purposes.
          To be blunt, it is basically a bit bizarre to rip 16/44.1 CDs to any higher bitrate. It does absolutely nothing other than create larger files. Audio is not changed.
          • thexfile
            • Jul 2010
            • 177
            Analog loop.
            • VBJohn
              • Mar 2021
              I'm curious about when I see Hi-Res music vendors (HD Tracks, Pro Studio Masters, etc.) offering albums/songs in AIFF, FLAC, ALAC, etc at 16 bit/44.1kHz, would these be the exact same quality audio files that I can RIP with CD Ripper?
                Yes!
                • VBJohn
                  • Mar 2021
                  Yes!
