Changed Behavior In Character Mapping
    • 44062
    Re: Changed Behavior In Character Mapping
    Try restarting Windows in safe mode (with networking):
    Then see if filename and DSP effect works.
    • husker
      • Dec 2013
      • 62
      Safe mode had no effect.
        • 44062
        If you look in dBpoweramp Control Center it says Release R17.2 and further down Registration Status: Reference Registered?
        • husker
          • Dec 2013
          • 62
          Screenshot below. "Fully Registered, No Restrictions"
            • 44062
            Which Windows version do you have?
            • husker
              • Dec 2013
              • 62
              #21
              Windows 10 Enterprise 20H2
                • 44062
                #22
                Do you have access to any other computer you can test on?
                • husker
                  • Dec 2013
                  • 62
                  #23
                  OK. I did some addional testing. The issue happens whenever I create a new profile.
                  1. The default profile shows the filename correctly.
                  2. As soon as I create a new profile, even copying settings from the default profile, the filename column blanks out, and will not process the DSP.
                  3. This happens on two computers, both Windows 10 Enterprise 20H2.
                    • 44062
                    #24
                    Which encoder are you using? if using Multi-encoder then it would not show filename there.
                    • husker
                      • Dec 2013
                      • 62
                      #25
                      Yes, I am using multiencoder.
                      • husker
                        • Dec 2013
                        • 62
                        #26
                        OK, narrowing this down a bit more - it is the multiencoder that creates the problem.
                        1. Create new blank profile, select MP3, add the DSP effect to replace ':' with ' - '
                        That works perfectly. However, if I do this:
                        2. Create new blank profile, select multiencoder, add MP3, add the DSP effect to replace ':' with ' - '
                        That will NOT work, and the DSP is not processed.
                        • husker
                          • Dec 2013
                          • 62
                          #27
                          Spoon - can you reproduce the above?
                          • husker
                            • Dec 2013
                            • 62
                            #28
                            OK Spoon, I can reproduce the error 100% of the time using multiencoder.
                            I can set different profiles for single encoders (Flac and MP3) with all the DSP effects, and they all work correctly.
                            If I set a multiencoder using the exact same (saved then load) DSP effects, they fail.
                            I have to rip CDs twice now (one each profile), so it would be helpful to have this fixed.
                              • 44062
                              #29
                              We will look at this when next updating dbpoweramp, the dap effect is not being used for naming when within multi encoder.
                              • husker
                                • Dec 2013
                                • 62
                                #30
                                Can you reproduce the issue? Do you know why it is happening? It seemed fine on R16.
