ripping into multiple formats / directories
  • mfl
    • Oct 2020
    • 9
    Re: ripping into multiple formats / directories
    I understand and appreciate that. What does not make sense to me is to create a name space when the ripped output is piped into the different encoders.
    In the setup which now works for me - with very similar requirements like you outline - it would have been logic to define output per decoder. And probably feed into different instances of the same decoder. For none of these functions the name defined in CD Ripper is relevant.
    • BKSF
      • Nov 2020
      Originally posted by mfl
      Thanks, that seems to work. This is however one of the worst user interfaces I have ever seen where you have to provide redundant information otherwise it is not working as expected with any warning/error
      Honestly I would not buy this again.
      Thank you for your persistence in getting this query solved. I was stymied by the exact same problem and never in a million years come up with the solution on my own. That being said, I do think the tool is great in every other way, and am a happy user.
      • ramblingleftie
        • Nov 2020
        I'm trying to do this as well but with no success. I've tried following the instructions above but the software still rips both the FLAC and WAV files to the same directory.Click image for larger version
Name:	Screenshot 2020-11-29 at 14.33.05.jpg
ID:	294368Click image for larger version
Name:	Screenshot 2020-11-29 at 14.32.56.jpg
ID:	294369Click image for larger version
Name:	Screenshot 2020-11-29 at 14.32.46.jpg
ID:	294370Click image for larger version
Name:	Screenshot 2020-11-29 at 14.31.00.jpg
        Any pointers will be most welcome!
          • 44080
          In CD Ripper you cannot use "source" on the naming of the multi-encoder, it means nothing. Instead you specify the full path and naming on multi-encoder.
            Super Moderator
            • 1375
            Thanks for your feedback.
            [sourcefilename] is allowed with CD Ripper & Multi Encoder but behaves inconsistently. Please do not use it, use something else such as [track] - [title] instead.
            This is addressed in latest dBpoweramp R17.3 beta, [sourcefilename] is expanded to [track] - [title] for Audio CDs.
            While [sourcefilename] should not be used with CD Ripper, I opted not to block it in order to keep naming schemes interchangeable with other parts of dBpoweramp.
