1 specific audio CD not detected
  • Dynky
    • Jun 2016
    I'm running dBpoweramp (17.1) on a macbook Pro (Catalina 10.15.6), with an external LG drive (M-Disc) which always performed flawless.
    Today however, I ran into a problem with 1 specific audio CD that isn't detected by dBpoweramp, the front LED of the drive blinks and I hear it spinning from time to time, but the application screen shows no progress as usual.
    Any ideas what to try?
    • 46198
    Re: 1 specific audio CD not detected
    It is likely the cd drive its self cannot read the disc, try iTunes and see if that can see the disc.
    • Dynky
      • Jun 2016
      iTunes doesn't see it either.
      Unfortunately I don't have another drive
      • Holden4th
        • Jul 2020
        • 13
        I had one CD like that and all I did was clean it. It looked clean before I wiped it.
