CDex will not connect to remote freedb
  • oldyellr
    • Jun 2020
    I've googled this problem and have seen a few posts from this forum, but nothing that was of any help. This started happening a couple days ago on my Windows 7 and Windows XP computers using different versions of CDex, versions 1.40, 1.82 and 2.23. When I click Read remote freedb I get this:
    Opening Connection
    Failed to make connection, please check network/proxy settings
    When I enter the titles manually (or use a CD I've ripped before) and try to Submit to remote freedb, I get this:
    Connection Failed for reason
    "An invalid argument was supplied."
    The only way I can rip now with CDex is to enter the information manually. I've used CDex for many years and this just started happening now. What could be wrong and how can I fix it?
    Re: CDex will not connect to remote freedb
    Freed has been discontinued, you could try dBpoweramp from this website, it uses 4 different metadata providers.
    • oldyellr
      • Jun 2020
      Darn! I used to also use Windows Media Player for ripping, but it was not as good at finding titles and doesn't seem to find any at all now. I also just downloaded Kat CD Ripper, which seems to be a clone of CDex and gets the same errors. I'll try dBpoweramp Music Converter to see if I have any luck.
      • oldyellr
        • Jun 2020
        I just tried the CD ripper in dBpoweramp Music Converter with my Robbie Robertson CD I had never ripped and it worked great, finding all the titles, information and cover art. With CDex I always had to search for cover art afterwards and add it using Mp3tag. I would always resize cover art down to 300x300 but it gave me 800x800, no big deal and not worth the time to downsize it with Mp3tag. Great program!
          • 1932
          You can configure the album art size.
          But the best feature is accurate rip.
          • oldyellr
            • Jun 2020
            I found the album art configuration. Not sure what AccurateRip does. I ripped the same CD twice, first at 256 kbps, then at 192 kbps. The first time tracks 1 and 5 came up X Inaccurate, the second time 1, 2 and 5 were X Inaccurate. But I found nothing wrong listening to them. What is the purpose and can Inaccurate tracks be fixed, or should I just turn it off if I can't tell the difference?
