Accuraterip problems
  • Chalie1729
    • Feb 2020
    Using version 16.6 - when using cd ripper prior to ripping screen says cd in accuraterip below track listing whereas when ripping completed each track says not in accuraterip - what am I missing please?
    • 1914
    Re: Accuraterip problems
    The checksums of your rip does not match the checksums in the accurate database rip. In other words: the possibility, that the rip is faulty, is very high.
    Have you configured C2 error pointers? Try to disable the C2 error pointers.
      • 46198
      You could have a different cd pressing than the one stored in the database.
        • 6189
        I see this relatively often. It's not an error. It's just that your pressing of the CD is not likely the one that's in AccurateRip.
        • Chalie1729
          • Feb 2020
          Thanks for the suggestions guys - much appreciated.
          Since posting I have changed the ripping method from Defective by Design to Secure and all works ok.
