AccurateRip Key Disc / offset detection
  • conduitnas
    • Nov 2019
    Setting up DB and cannot find a disc that will successfully set off set. Tried 30+ CD's and get 'This key disc cannot be used for offset......' warning every time. When I first installed DB this worked fine, but now doesn't for some reason. I can rip CD's and they seem OK, but they are not resulting from AccuaretRip checks. What can I do?? Installed on HP laptop, 64-bit Windows 10. Thanks
    • 44044
    Re: AccurateRip Key Disc / offset detection
    What name is detected for your CD drive?
    • conduitnas
      • Nov 2019
      hp DVD RAM
      H21 379440
        • 44044
        This drive is not in AccurateRip, you will have to have 3 matching key discs for it to detect and work with it. Keep feeding discs until it configures.
        • conduitnas
          • Nov 2019
          Put about 50 discs through it by now. Can you suggest key discs that will work - is there a database? My collection isn't that obscure!
            • 44044
            The discs cannot be used if there is a different pressing present, so new releases are most likely to configure. There can be no list of discs because 3 months after a cd is released, they could create a new pressing of that CD and there are 2 instances of that CD in the database.
            The other option is to go for an external CD drive, one which is already known to AccurateRip, that would configure with any known disc (over 2 million).
            • conduitnas
              • Nov 2019
              Switched from laptop to PC and different drive. No problem with that so sorted. Thanks
              • mdm1979
                • Mar 2016
                • 9
                I'm using an external blu ray drive. ASUS BW-16D1H-U
                I'm having the same issue. If there's an easy fix please advise. I'd prefer not to have to buy another drive.
                  • 44044
                  This drive is in the database, so you would only need 1 matching disc. It is in as 'ASUS - BW-16D1H-U' it appears as this name exactly in the program?
                  • mdm1979
                    • Mar 2016
                    • 9
                    Yes, that is correct. I've tried 5 common discs so far. I'll keep going. Is there a way to avoid last track re-rips? Some error numbers are into the thousands.
                      • 44044
                      Disable C2 pointers if enabled.
                      • Magne
                        • Feb 2015
                        I just got a new PC and a new external optical drive.
                        The drive is Asus SDRW-08D2S-U.
                        With this, I can not have Accurate rip verified since the offset can not be detected.
                        I had the same problem with Verbatim 98938.
                        What can be done with this?
                          • 44044
                          Keep feeding it discs until it configures.
                          • Magne
                            • Feb 2015
                            I have tried Love over gold, Born in the U.S.A, Hunky Dory, The final cut, Whish you were here. Same problem with all. With the last one, it did not ask about configuration at all - after many attempts.
                            Another thing - I now get a notepad file in the album directory. How can I turn that fetature off?
                            I'm also looking for a way to turn off the artist name as the first part of the name of the song - 01 Pink Floyd - Shine on you crazy diamond
                              • 44044
                              You must have enabled secure ripping log on the secure ripping options page.
                              To remove the artist, click 'Set' next to naming and remove the last '[artist] - ' from the string.
                              You might have to try 20 to 40 CDs at least if your drive is not in the database. If it is not asking to configure accuraterip, perhaps it is already configured.
