Metadata Retrieval very slow - but i already use Discogs not AMG - help
  • alex1977
    • Feb 2017
    • 33
    Hi - essentially like my title says, metadata retrieval takes about 3+ minutes - i read somewhere about unchecking AMG - but i don't have AMG as an option, and i see discogs is already checked - i wish i could get this fixed - thank you!
    • 45831
    Re: Metadata Retrieval very slow - but i already use Discogs not AMG - help
    Is it always slow? sometimes some providers go off line.
    Try unchecking the different providers one at a time, click the refresh button to re-read from the Internet until you find which one was slow.
    • alex1977
      • Feb 2017
      • 33
      Hi - That makes sense and that's what i was kinda thinking - can you clarify please - so i get what you want me to do, but what are you saying - i.e. unclick say DISCOGS - then try ripping a CD and see if speed changes - if not, re check Discogs and then uncheck another and repeat - yes? - What did you mean by click the refresh button.
      This is what i have checked - Discogs, GD3, Musicbrainz, freedb, and Intelligent Data from all Meta Providers - which would suggest i start with i was going to say the last?
      • alex1977
        • Feb 2017
        • 33
        UPDATE - it seems unchecking Intelligent DAta from all Meta Providers didn't make a difference (of course maybe it didn't take - i was going to be sure by closing app and restarting later) - but then i checked it again, and i unchecked FreeDB - and the next 7 cds i got back 'no meta data found' - strange, would make me think that FreeDB is the only one getting the data for all my rips. (So i checked that back on and it just got the data for the next cd) - so later i will try unchecking others to try and get it to not be slow in meta data retrieval - still at like 3+ minutes each time. And yes to answer your original question it's always slow.
          • 45831
          There is no need to actually rip the CD, uncheck and click the refresh button on the tool bar.
