CD Ripper not ripping to FLAC Help!
  • AlRose1978
    • Sep 2019
    Hey Guys...was hoping someone may be able to help me. I have been trying to rip several discs to FLAC files. Each time it pulls date from the tracks but the length is always Zero. Its not pulling any audio for some reason. Am I missing something? Doing something wrong? The WAV setting rips with no issues.
    Thanks in advance
    Al Rose
    • 1932
    Re: CD Ripper not ripping to FLAC Help!
    Did you update to the latest version? There have been problems within the flac libraries.
    • AlRose1978
      • Sep 2019
      I will try that to be sure. Thanks for the tip!
      • AlRose1978
        • Sep 2019
        That worked perfectly. Thank you so much!
        Al Rose
