Higher sample offset = worse drive?
  • Nubben
    • Apr 2008
    • 156
    Hi all,
    Will a higher sample rate offset (say +667) make for a worse accurate drive than a +6 sample offset drive?
    Thanks!
    Henrik
    • 1914
    Re: Higher sample offset = worse drive?
    The offset is specific for a drive. AFAIK without the right offset for your drive you will not achieve an accurate rip (a different checksum).
      • 6189
      Originally posted by Nubben
      Hi all,
      Thanks!
      Henrik
      No.
        • 1914
        Maybe I understood the question in a different way than Gary. Maybe my limited english is the reason why.
        If CD Ripper indicates an accurate rip, the rip is accurate and the offset and the drive do not matter at all.
        But if you configure a wrong offset for your drive, I think that you will not be able to get an accurate rip (I understood the question that way around).
        What you think Gary?
          • 6189
          Agree with you Dat Ei. There is no fundamental reason why larger offset affects rip quality. Of course drive should be set up properly as you note.
          • Nubben
            • Apr 2008
            • 156
            Thank you both for taking your time. I am struggling to get my head around this particular drive I have purchased - have another thread going here as well: https://forum.dbpoweramp.com/showthr...ns-please-help!
