New drive - have a few questions - please help!
  • Nubben
    • Apr 2008
    • 156
    Re: New drive - have a few questions - please help!
    Hi Spoon, ok thanks for your reply. Please can you just also answer this question (and I will go away....):
    If I add the +667 offset manually and continue using the drive with that offset (for difficult to rip CDs - it has already ripped a CD accurately which only could be ripped as Insecure on two other drives) as long as I get either an Accurate rip or it is Secure?
    Many thanks
    Nubben
    • Nubben
      • Apr 2008
      • 156
      Many thanks
      Nubben
      Hi Spoon, was wondering if you would be able to opine on this? Many thanks!
      Nubben
        • 45856
        If you manually enter the offset then AccurateRip will not function (on the PC).
        • Nubben
          • Apr 2008
          • 156
          Thanks Spoon - but I thought you could not enter the offset manually on the PC? I am on Mac, where I can enter it manually. So:
          1. Will it still work on the Mac; and
          2. Presumably if I do not rely on AccurateRip using the Secure (only) method it would still be ok?
            • 45856
            It would probably work OK on the mac.
              • 6167
              #21
              Yes, probably OK most of the time, but in my opinion, you don't want to be ripping with a drive that does NOT support AccurateRip. AccurateRip is very valuable and why bother going through the secure ripping process with a drive that doesn't support AR? I suppose you could rip using SECURE ripping and no AR, and then later check those ripped files for AR match using PerfectTunes.
              • Nubben
                • Apr 2008
                • 156
                #22
                Ok, many thanks Spoon - much appreciated.
                • Nubben
                  • Apr 2008
                  • 156
                  #23
                  Many thanks for that Gary - much appreciated
