Multi Encoder - not writing second disc in multi-disc sets to log file
  • Nubben
    • Apr 2008
    • 154
    Hi Spoon/All,
    I have just ripped a 2-CD set using the multi-encoder w/ FLAC and ALAC as the encoders. I have set this up to write to two individual folders underneath the album folder:
    Album Name
    FLAC
    1-01 Track name.flac
    1-02 Track name.flac
    Artist - Album Name.txt
    ALAC
    1-01 Track name.m4a
    1-02 Track name.m4a
    The resulting log file is put in the FLAC folder perhaps because I have that encoder listed first in the encoder settings however and more importantly the log file is only showing the first disc and not the second.
    Also, how can I tell dBpoweramp to put the log file in the root Album Name folder rather than in the FLAC folder?
    I'm on macOS Mojave and dBpoweramp 16.5
    Many thanks!
    Nubben
    Super Moderator
    • 1371
    Re: Multi Encoder - not writing second disc in multi-disc sets to log file
    Thanks for the bug report.
    The problem has been confirmed and will be fixed shortly.
    Using /../ seems to do the trick, causing parent directory to be used:
    [rippedtopath]/../[IFVALUE]album artist,[album artist],[IFCOMP]Various Artists[][IF!COMP][artist][][] - [album].txt
      Super Moderator
      • 1371
      Fixed in new beta-
      R16.6 beta continues where R16.5 beta was abandoned - R16.5 stable was made from a different code branch adding bug fixes on top of R16.4 codebase. Current version: R16.6 beta 9 Notable differences from R16.5 stable: Supports Mac OS Mojave Dark Mode Lowest supported Mac OS version is 10.10 "Yosemite". OSX Mavericks
