CD Drive sample offset question [Mac]
  • icassu
    • Oct 2018
    Just start using dBpoweramp, running Mac OS 10.13.6 on a 2014 Mac Book Pro, and using an Apple USB SuperDrive.
    In configuring Accurate Rip settings, a dialog window popped up along the lines of the drive isn't recognised, would you like to enter a manual offset (not entirely sure of the details), which I left at 0.
    Having a bit of a Google it seems that the offset should be +6. Having ripped several CDs the log files show a consistent pressing offset of +6 it would seem to support that (assuming these are related, this is all new to me so if I'm spouting nonsense please forgive my lack of knowledge!).
    Is this something that I can manually adjust? Or clear dBpoweramp's record of the drive to allow me to configure it again? Or is it something I don't need to worry about in the first place as Accurate Rip seems happy enough?
    Many thanks.
    Re: CD Drive sample offset question [Mac]
    If you are confident then enter -6, however 6 samples are in-audible and accuraterip works without you entering this value, so nothing really is gained or lost from either way.
    • icassu
      • Oct 2018
      Thanks for your reply. How would I edit this, the value looks to be "locked in" in the software?
        It cannot be edited.
        • SOC0001
          • Sep 2020
          Hi Spoon
          I have just bought dBpoweramp for Mac and I have made the same mistake described above in this thread.
          Without checking the set-up instructions (shame on me), I have entered a "10" in the Sample Offset field.
          After reading the instructions later, I understand that I have for the software to recognize the CD Drive which is a Apple - SuperDrive.
          After looking for a way to revert this, I decided to remove everything from my Mac and download the software to start all over again.
          But, nope, it did not work, Somehow it still showing sampling offset +10.
          What can I do? Is there a way to clean everything up and start from scratch?
          I have now seen in the instructions that the Sample Offset figures are significantly different.
          If I cannot do anything (why?), which will be the impact on "ripping quality" if the +10 remains?
          Thanks for your advise
            • 1685
            Behavior changes in the new beta-
            You can now manually enter the offset again any time.
            Note that dBpoweramp settings can be fully reset by deleting "Library/dBpoweramp" folder in your home folder, in terminal:
            Code:
            rm -rf ~/Library/dBpoweramp
            ... but you should not have to do this.
