RE: Tagging 'Quirky' Question (help?)
  • monsterjazzlick
    • 1764
    Hi folks,
    I have opened a new thread because hopefully the discussion won't be too drawn out and many of my other threads are already verbose. However, moderators please relocate if you see fit.
    I am ripping the CD: Bach - Well-Tempered Clavier (played by Edwin Fischer), books I and II:
    I am trying to tag the 2 discs but they will not open in ID-Tagger. All of my other rips do, however. I mean, I am not given the option to use ID-Tagger.
    Please see screenshot:
    Perhaps it's a quirk or maybe I need to adjust a specific setting?
    Many thanks in advance for any kind assistance offered here.
    Paul
  • monsterjazzlick
    • 1764
    Re: Tagging 'Quirky' Question (help?)
    I have tried re-ripping the CD but the results (as per above) remain the same.
    Paul
      What does the file explorer context menu normally show, when selected on other flacs?
      • monsterjazzlick
        • 1764
        I think this is what you are referring to:
          So, the context menu works as expected, on flacs in the Chick Corea - Return To Forever folder but not in the Bach - Well-Tempered Clavier folder. The context menu is a feature of Windows 10 File Explorer, not dBpoweramp.
          If you copy one of the Bach - Well-Tempered Clavier flacs to the Chick Corea - Return To Forever folder, does the context menu now work as expected, on the copied flac?
          • monsterjazzlick
            • 1764
            I thought I would quickly try it once before copying the CD into another Genre/Artist folder, and it seems to have corrected itself?! I have no idea how or why!?
            I have another similar-ish issue with recently ripped Beethoven symphony CD which I will post tomorrow, probably in a new thread.
            Cheers.
