Accurate Rip Problem - SATA UHD in USB3 Enclosure
  • TLBradbury
    • Apr 2011
    • 16
    I have a Pioneer BDR-211UBK UHD (4K) drive that I had to install in an external USB3 enclosure (Vantec NST-536S3-BK) due to the lack of 5.25 bays on my new system. I was able to get dBpoweramp configured for Accurate Rip just fine, but nothing I rip will match the Accurate Rip checksums. While the results are always a secure rip, they won't match.
    The drive itself is a step up from my previous (BDR-2209). I am getting frustrated with the current situation, and I am now ripping on my old box again to be certain of accuracy. I don't know if this is due to the drive being in the external USB enclosure, but I would be happy to provide any information that might lead to a solution.
    Re: Accurate Rip Problem - SATA UHD in USB3 Enclosure
    Try disabling C2 pointers if you have them enabled.
    • TLBradbury
      • Apr 2011
      • 16
      Bingo! That did the trick.
      Thanks, Spoon!
