How to rip DJ mixes CD's so there are no gaps between tracks
  • bart smh
    • Mar 2018
    I'm ripping DJ'a mix CD and the songs overlap during the mixes so the music is continuous.
    Which settings needs to be set so that there are not gaps between the various tracks so that it sounds like a DJ's mixed set.
    Using that apple lossless format as it keeps album artwork etc. and will work with sonos. AIFF doesn't work well with sonos and keeping metadata file info.
    Please help.
    tx.
    bart.....
    Re: How to rip DJ mixes CD's so there are no gaps between tracks
    You will need to check whether your playback software supports gapless playback for your chosen file format.
    If not, you can use Menu >> Rip as One
