Multi CPU Ripping won't work anymore...
  • Algonquin
    • Feb 2018
    Hello,
    I have recently upgraded my desktop and I've noticed an issue when I'm ripping CD's. Even though I forced multi CPU, it will only rip one track at a time and I can't figure out where the problem is.
    I used to run a Quad Core Q9650 and it ripped 4 tracks at once. Not sure if I'm using the right wording here... but what I mean is that I had action on 4 tracks at once all the way from the start to the end.
    Now I have a 8700K and can't rip/process more than 1 track at a time.
    I have tried the Media Converter and I can convert 16 files at the same time (new cpu has 6 physical core and 12 hyper threads) so this setup should be able to rip/process 16 track at once, no problems.
    I have tried running CD ripper as admin, same thing. Can't get it to rip more than 1 track a a time...
    So now it is slower to rip with the new CPU than the prehistoric one that I had.
    Any help would be appreciated.
    Thanks!
    Joe
    • 1932
    Re: Multi CPU Ripping won't work anymore...
    Hey Joe,
    are you sure that you've ripped 4 tracks with CD Ripper at once and not converted 4 tracks with Batch converter at once? Which version do you use? Reference Registered?
    • Algonquin
      • Feb 2018
      Hi Dat,
      I think I got confused with Ripping and encoding. Is it possible that my older CPU took too long to encode and that's why I was seeing 4 tracks processed in queue as opposed to now seeing it fly out?
      I got version 16.4 registered.
      Not sure how fast this should go but if I rip a CD which contains 327MB FLAC uncompressed, it takes about 1:22 from start to end.
      Is that good or slow?
      I have been using this software only since a few months, I'm sure I have lots to learn about it.
      Thanks for a quick help.
      Joe
        The CD drive will be the slow part, not encoding.
        Ripping a CD in 1 minute is as fast as the CD drive can supply.
