Drive Read Cache(Detect) do not response.
  • ampxyz
    • 22
    Hello.
    Ripping Method --> Secure Settings --> Drive Read Cache(Detect) do not response.
    OS: Win 10 Pro.
    Two changes were made in OS before the issue:
    1. To install last main update for OS at the date.
    2. Deleting obsolet *.dll.
    I'll be thankful for any help please.
    • 46143
    Re: Drive Read Cache(Detect) do not response.
    Does normal ripping work?
    By not work, you mean the page detecting cache does not show? it used to work?
      OS: Win 10 Pro.
      How did you perform 2. Deleting obsolet *.dll?
      • ampxyz
        • 22
        Thanks for yor help.
        I just ripped a cd with the issue and did ok.
        By not work i mean that page detecting cache shows, seems to try detecting showing since the first moment "do not response", and after some time it informs that drive does not cache, click "ok" and it stores results (None) in main page secure settings: before cached 75kB.
        Went further and tested Fua, ok; tested C2, ok.
        Note: the function works ok in EAC.
        • ampxyz
          • 22
          Thanks for your help.
          2. I rectify; "Shared DLLs" i used with Auslogics Boostspeed 10, registry cleaner.
            • 46143
            It is working, it is detecting no read cache. If you want the safe option, leave on 1024KB
            • ampxyz
              • 22
              Although before dBpoweramp detected drive read cache is 75KB?
                • 6185
                you can use 75kb, but 1024KB is the safe option as spoon noted. I always use 1024KB for all drives no matter what.
                • ampxyz
                  • 22
                  I see.
                  Thanks to all of you for helping me.
