media problems ....
  • Hitarth
    • Sep 2017
    • 220
    media problems ....
    hi,
    I have ben using dBpower for a long time and this is he 1st time I have come across some CDs where they look absolutely FLAWLESS to the naked eye.... once I start ripping them ... the 1st track is ERROR ... there is no scratch on the begging of the CD neither on the full CD .... I settle for ripping that track as a DANAGED track, hence using that settings.
    Yes, the CDs were lying in the closet for many years .... is there a possibility of the media deteriorating or rather deteriorated ???
    Re: media problems ....
    CDs can contain manufacturing defects as well as scratches.
    What is the error?
    Yes, it's possible.
    • Hitarth
      • Sep 2017
      • 220
      [QUOTE=mville;181201]CDs can contain manufacturing defects as well as scratches.
      apparently these CDs were regularly used once upon a time ...
      • Hitarth
        • Sep 2017
        • 220
        the CDs are super clean ... scratchless ...
        • Hitarth
          • Sep 2017
          • 220
          What is the error? [/QUOTE]
          the track is an ERROR in red & there is no file in the folder ..
            There is a difference between ripping a CD in CD Ripper and playing a CD in a CD player.
            CD Ripper tries to extract the digital audio data exactly, to obtain a bit perfect copy of the data. It will keep trying until either it does or stops depending on the CD Ripper Secure Settings and then reports the outcome, including any errors found.
            A CD player is designed to read a CD, and when it gets errors it then interpolates the missing digital audio data, which hopefully on playback, you will not hear.
              This is another problem, so you'll have to provide more info and/or post the secure extraction log.
                As I said, CDs can contain manufacturing defects as well as scratches.
                Manufacturing errors are often not visible to the naked eye.
                • Hitarth
                  • Sep 2017
                  • 220
                  yes, you are right ... many thanks
                  • Hitarth
                    • Sep 2017
                    • 220
                    thanks mville, I had a small setting problem, it seems to be doing fine now
                    many thanka
                    • Hitarth
                      • Sep 2017
                      • 220
                      yes, I am aware of this ....
                      many thanks
                      • Hitarth
                        • Sep 2017
                        • 220
                        many thanks
                        hi,
                        i have a problem where dbpower cannot read a CD, it shows as a blank CD, where as the same CD with he same drive will rip with Easy Audio Copy or EAC or even CUEripper ...
                        any input is welcome
                          • 1914
                          Did you try to click the rescan button?
                            • 46198
                            Is it just one CD or all? check the ripping mode is not set to 'defective by design'
                            • Hitarth
                              • Sep 2017
                              • 220
                              it could happen to any CD.
                              no, the ripping mode is not set to "defective by design"
                              strangely it works on other ripper, though on the same drive. i just ried on fre:ac too .. it worked fine.
