dBpoweramp - strange goings on with CD ripping - Help!
    • 4015
    #46
    Re: dBpoweramp - strange goings on with CD ripping - Help!
    Originally posted by Dat Ei
    If you use a Windows System (Windows 7 or newer) you can use the Windows inherent tool "robocopy", which is a very powerful tool...
    Thank you Dat Ei, for the excellent info.
    Have you tried using the .bat file within Task Scheduler?
      • 1752
      #47
      No, actually not. Usually I rip a batch of CDs and at the end of that I just double-click my batches.
      As long as your network connections are established, I don't see a point, why those batches will not work and start if they are invoked by the task scheduler.
        • 5762
        #48
        nice tutorial on robocopy. Seems very useful. I've historically been using freefilesync to keep my main library files synched to my various backups.
        p.s. I think the OP is a Mac user.
        • MrWriter
          • Nov 2017
          • 35
          #49
          Yup, Mac user.
