Best FLAC
  • AllenC
    • Dec 2017
    • 10
    Re: Best FLAC
    Thank you for the reply.
    Yes, I did a bit of experimenting and did notice the longer rip time, but agree that in my case, that's not really an issue. I'm not a tech guy, so it's hard for me to think of potential consequences (you don't know what you don't know!), but for example, although I chose FLAC, for one because it seems that it is a compatible format with many players (arguable, I'm sure), I wonder whether the compression could be an issue with some. or in the future? For now, I will be streaming through a Sonos system, which seems to work fine so far with a few newly ripped CD's (classical naming formats are another story for another thread).
    Maybe I am being true to form in that I'm complicating things, but I want to start right!
    Thanks again.
      • 1752
      Re: Best FLAC
      You can compare flac compression with zip compression of your other data files. No matter what compression level you chose you won't loose a single detail.
        • 4015
        Re: Best FLAC
        In the distant past, with older/slower systems/cpus, there may have been issues when decoding flacs with higher compression levels, not that I ever experienced any problems.
        Regarding the future, if there were any problems, which I seriously doubt, you are able to re-convert your flacs with a different compression level. If you are still unsure, stick with the default/recommended compression level 5. Personally, I use compression level 8.
        • Jailhouse
          • Sep 2016
          • 388
          Re: Best FLAC
          [...] I chose FLAC, for one because it seems that it is a compatible format with many players (arguable, I'm sure), I wonder whether the compression could be an issue with some. or in the future?
          All the hard work at higher compression levels is done during ripping by the encoding software. To the CPU, there is no difference between decoding FLAC files compressed at Level 8, Level 1, or anywhere in between.
          • AllenC
            • Dec 2017
            • 10
            Re: Best FLAC
            Thanks everyone. I'm convinced! I'll go with the recommended compression and "enjoy" the benefit.
            • monsterjazzlick
              • 1764
              #21
              Re: Best FLAC
              Hi Allen,
              I went the 'recommend' level also since I purchased four months ago.
              Paul
              • jultsu
                • Mar 2016
                • 58
                #22
                Re: Best FLAC
                Originally posted by evasv
                I agree
                This I don't understand, would you care to explain more?
                Have you seen the video in the link? Do you actually agree with what Ben from CA says?
                I meant that a DAC / digi-interface can do both (buffering and upsampling.)
