Naming & Placing of Two Versions of Same CD
  • monsterjazzlick
    • 1764
    Hi folks,
    I purchased a double-CD of Miles Davis's "Kind Of Blue" 1959 recording:
    CD Disc-1 is the original vinyl recording and CD Disc-2 is the exact same album, except in STEREO version.
    And so my questions are, please:
    I have not ripped them as CD Disc 1/2 and 2/2, but rather as individual albums (although it is a double-CD).
    For the TITLE of each CD, I have used: "Kind Of Blue (Mono)" and "Kind Of Blue (Stereo)".
    I would be grateful if anyone might share their thoughts and preferences regarding the aforementioned.
    Many thanks in advance.
    Paul
    EDIT: Here is how the two discs appear in foobar:
  • Jailhouse
    • Sep 2016
    • 388
    Re: Naming & Placing of Two Versions of Same CD
    It won't hurt anything to do it that way, and it will be easy for you to tell at a glance which is which. I can't see any reason not to go that route.
    • monsterjazzlick
      • 1764
      Thanks JH,
      The other option would have been to use the CD 1/2, 2/2 scheme. I mean, it IS a double-album; though you may argue that it is 2 x SINGLE CDs!
      Cheers,
      Paul
      • monsterjazzlick
        • 1764
        Also, as you can see above, I used the same ARTWORK jpeg for both albums:
        Paul
        • Oggy
          • 703
          Hi folks,
          Paul
          [ATTACH=CONFIG]1768[/ATTACH]
          [ATTACH=CONFIG]1767[/ATTACH]
          Hi Paul,
          That looks logical, and I would certainly use Kind Of Blue [Mono]. If the stereo version was the only, stereo version I had, I'd use simply, Kind Of Blue. If it was a second stereo mastering, I would do what you have.
          I would also use the same cover for both, but would use the original sleeve, without any stickers.
          But this is purely personal preference.
          • monsterjazzlick
            • 1764
            Originally posted by Oggy
            Hi Paul,
            Cheers Oggy,
            The reason I chose the artwork I did was because most of the other available JPegs were of inferior quality. Also, I really like the stickers!!!
            But in any event, you would definitely treat the two albums as separate entities?
            Paul
