Tags, Tags, and more Tags ...
  • Jailhouse
    • Sep 2016
    • 388
    #91
    As you state, you can use a Y/N comment for COMPILATION.
    Not according to Gary, and I believe he's correct. I can use Edit ID-Tag to add a Compilation tag set to No--in fact, that's the only way I can add it, after which I can change it to Yes. This is part of a larger issue which I think has been addressed in the beta. In any event, the behavior is the same.
    But I am not sure if this would work, or how it would work, for a self created VOCALS tag? I was thinking was possible, with COMPILATION, because such albums are placed in a dedicated folder of their own[.]
    Are you proposing dedicated folders for vocals and non-vocals albums? That would make albums harder to find in File Explorer (more places to look, although a foobar library search shouldn't have a problem), and each group would need to have its own Compilation sub-folder. For me, that's rather messy.
    My use for a Vocals tag, should I implement it, will be to differentiate tracks, not albums. I have a fair number of albums with a mixture of vocal and instrumental tracks, and I'm not comfortable tagging those as either Vocals=Yes or Vocals=No. But I may want to be able to quickly find instrumental-only tracks.
    (Incidentally, your Gary-supplied foobar setup is different to mine. The look isn't the same, and my compilation albums reside in a Various Artists folder. Options! )
    Taking into consideration your kindly suggested AlbumHasVocals tag, then this might be a good solution for the latter-mentioned.
    I believe it's a useful alternative, whatever you name it. Adding it only to the tracks in albums with vocals would likely do the trick, as you then just search for the existence of the tag. Or make it a Y/N and add the tag to all tracks. The more expert members of the forum may have something to say about the advantages and disadvantages of each choice. I'll be watching!
    • monsterjazzlick
      • 1764
      #92
      Thanks Gary/JH,
      I will have a think over the next few days ...
      Cheers,
      Paul
      • monsterjazzlick
        • 1764
        #93
        Hi JH,
        Again, after much thinking and some testing out, I feel this is another tag I might actually be better without! It is not imperative and I am running into possible grounds of over-tagging.
        As you say, folder-structure-wise, it's going to get messy.
        I was intending to tag such albums which were predominantly VOCALS rather than single tracks. If I was to follow your own logic then it is going to be another long-winded task for me to compile alongside ripping my entire CD collection (albeit I am not saying that there is anything wrong with your suggested system).
        Cheers,
        Paul
        • Boss4001PL
          • Oct 2017
          Hello. i Have a problem. i want to change title for my files from oryinal file name using id tag procesing. how can i do it? i have a lot of files. i cant change title one by one
            • 4021
            #95
            it's probably best, if you create your own thread. In answer to your question, you can use the Arrange Audio utility codec.
            • Boss4001PL
              • Oct 2017
              i instaled but how to use this?
                • 4021
                #97
                [ATTACH=CONFIG]1800[/ATTACH]
                That is the ID Tag Update utility codec, not the Arrange Audio utility codec.
                • monsterjazzlick
                  • 1764
                  #98
                  Hi guys,
                  What would be the best way to ARTIST SORT the band: 'Blood, Sweat & Tears', please?
                  I have been using the naming scheme:
                  'Orchestra, Mahavishnu, The';
                  'Report, Weather'
                  'Davis, Miles'
                  for my rips to date.
                  Would it be: 'Tears, &, Sweat, Blood'?
                  I am not really sure about the commas or the 'and' symbol?
                  Many thanks,
                  Paul
                  • Jailhouse
                    • Sep 2016
                    • 388
                    #99
                    'Davis, Miles' is standard operating procedure, as you would find him in the 'D' section when looking for his works in a shop.
                    However, the others should be 'Mahavishnu Orchestra, The' and 'Weather Report'. You would expect those last two to be in the 'M' and 'W' bins, respectively.
                    In the same vein, 'Blood, Sweat & Tears' should be listed exactly that way.
                      • 4021
                      'Report, Weather'
                      'Davis, Miles'
                      I don't think you are understanding the use of Artist Sort. You have The Mahavishnu Orchestra sorted under O and Weather Report sorted under R. This does not make sense to me.
                      I agree with Jailhouse and would have:
                      Artist = The Mahavishnu Orchestra
                      Artist Sort = Mahavishnu Orchestra, The
                      Artist = Weather Report
                      Artist Sort = Weather Report
                      Artist = Blood, Sweat & Tears
                      Artist Sort = Blood, Sweat & Tears
                      • Oggy
                        • 697
                        You've made me so very happy, with this explanation, obviously agree.
                        • monsterjazzlick
                          • 1764
                          JH,
                          To be honest, it's been that long since I visited a record store to buy a CD than I forgot about how - ordering - they might be stacked. But thinking about it, I agree with your protocol, thanks.
                          Paul
                          • monsterjazzlick
                            • 1764
                            Cheers Mville,
                            I have made those changes now.
                            But how, please, might you tag the ARTIST SORT for bands which include the leader's name alongside the size of the ensemble? For example:
                            Oscar Peterson Trio
                            Dave Brubeck Quartet
                            Miles Davis Quintet
                            Would it be:
                            Peterson, Oscar, Trio
                            Brubeck, Dave, Quartet
                            Davis, Miles, Quintet
                            Very much appreciated,
                            Paul
                              • 1757
                              From my point of view: while "Oscar Peterson" is a combination of a first and a last name and "Peterson, Oscar" is ok for a sort tag, "Oscar Peterson Trio" is a commonly used term in itself. But if you prefer to have "Oscar Peterson" in the near of his trio, quartet or whatever, why not the other way? It is your tagging!!! There are no standards except your own ones.
                                • 4021
                                Oscar Peterson Trio
                                Miles Davis Quintet
                                Would it be:
                                It all depends on how YOU want these artists sorted.
                                If you want Oscar Peterson Trio to be sorted under O, then Artist Sort = Oscar Peterson Trio is ok.
                                If you want Oscar Peterson Trio to be sorted under P, then Artist Sort = Peterson, Oscar, Trio is ok.
