Not according to Gary, and I believe he's correct. I can use Edit ID-Tag to add a Compilation tag set to No--in fact, that's the only way I can add it, after which I can change it to Yes. This is part of a larger issue which I think has been addressed in the beta. In any event, the behavior is the same.
Are you proposing dedicated folders for vocals and non-vocals albums? That would make albums harder to find in File Explorer (more places to look, although a foobar library search shouldn't have a problem), and each group would need to have its own Compilation sub-folder. For me, that's rather messy.
My use for a Vocals tag, should I implement it, will be to differentiate tracks, not albums. I have a fair number of albums with a mixture of vocal and instrumental tracks, and I'm not comfortable tagging those as either Vocals=Yes or Vocals=No. But I may want to be able to quickly find instrumental-only tracks.
(Incidentally, your Gary-supplied foobar setup is different to mine. The look isn't the same, and my compilation albums reside in a Various Artists folder. Options!
I believe it's a useful alternative, whatever you name it. Adding it only to the tracks in albums with vocals would likely do the trick, as you then just search for the existence of the tag. Or make it a Y/N and add the tag to all tracks. The more expert members of the forum may have something to say about the advantages and disadvantages of each choice. I'll be watching!
But I am not sure if this would work, or how it would work, for a self created VOCALS tag? I was thinking was possible, with COMPILATION, because such albums are placed in a dedicated folder of their own[.]
![Smilie](https://forum.dbpoweramp.com/core//images/smilies/smile.gif)
Taking into consideration your kindly suggested AlbumHasVocals tag, then this might be a good solution for the latter-mentioned.
