Tags, Tags, and more Tags ...
    • 5759
    Yes. And when the files load up, click CONVERT. Then choose ID Tag Update as the codec. Not flac. Start with only an album or two to test. I cannot even recall what you are trying to do. Delete all sort tags?
    • monsterjazzlick
      • 1764
      Hi Garym,
      After it scans (which takes a few mins), this pop-up appears - where I just don't see the option you kindly mention?
      Much apologies!
      Paul
        • 5759
        Hi Garym,
        Much apologies!
        Paul
        https://drive.google.com/file/d/1Dd6...ew?usp=sharing
        you must not have installed the ID TAG UPDATE codec from Codec Central yet. Install this then try again.
        EDIT. hmmm, supposed to be installed by default. Have you scrolled down on that popup list of codecs to see if it is listed. In fact you seem to be missing lots of codecs there. Are you windows or Mac.
        • monsterjazzlick
          • 1764
          Hi Garym,
          I'm on Windoze_10, PC.
          Yes, I have tried to scroll down the list many times, but to no avail.
          I think I noticed a small 'update' pop-up earlier this evening, but I got side-tracked preparing screenshots. I mean, I may not be on the most up to date version of Illustrate?
          Paul
            • 5759
            I am having the SORT issues on all 3 players.
            Foobar is installed on my PC and Amazon Fire.
            With the Sony Walkman, I just copied everything (from my PC) onto an SD-card and whacked it in! The only way you can manipulate the files, or similar, is by d/l Sony's dreadful s/w - which nobody uses.
            this is not an update issue. This option has long been available. So not sure the problem.
            • monsterjazzlick
              • 1764
              So I'm missing some codecs? Which is obviously why they're not showing up?
              • monsterjazzlick
                • 1764
                ... btw. I have Perfect Tunes so I could give this method a go tomorrow.
                  • 5759
                  I willl post a pic of what mine looks like tomorrow.
                  • monsterjazzlick
                    • 1764
                    Thank you, Garym
                      • 5759
                      Are you selecting BATCH converter. That is what you need.
                      • monsterjazzlick
                        • 1764
                        Yes I am. I believe I select this within the very first window which opens.
                          • 5759
                          See pic at link.. This is what I see when I open BATCH CONVERTER, select some files, then click CONVERT. Note that I have several codecs here that are not default and require installing. But the ID TAG UPDATE Utility Codec is supposed to be installed by default with the program.
                          • monsterjazzlick
                            • 1764
                            https://www.dropbox.com/s/70h7zejlw3...14.34.png?dl=0
                            Gee, wow; you have a massive drop-down list compared with mine! I think I only have about 7 codecs.
                              • 5759
                              Like I said, some of those I had to manually install. Most I don't actually need anyhow. Mostly need FLAC, mp3, and some of the utiility codecs like TEST CONVERSION, Replaygain, ID TAG UPDATE etc.I don't use WAV, OGG, AAC, Windows Media anyhow.
                              • monsterjazzlick
                                • 1764
                                Well I suppose they are handy to have if ever. I to don't use Wav. (unless it's a Cubase project), and WMA is a complete no-no! Unless Amazon are offering no other option (ie. hard-copy CD) the I have choice but to purchase certain albums as mp3 d/l's.
