Tags, Tags, and more Tags ...
  • monsterjazzlick
    • 1764
    Originally posted by GBrown
    I try to eliminate anything in the sort tags that is irrelevant. So I would simply show Corea, Chick and get rid of the quotes. Same for things like brackets, this makes it more consistent regardless of the tag to make sure they group together. It work for my library, currently around 25k songs.
    And for the record, I too am pretty diligent with my tags, have been since I started ripping my CD library around 2002 or so. And yet there are still titles that pop up when I shuffle the deck that I need to go back and find. Doubt I'll ever really be done!
    Hi GBrown,
    OK, I hear you. As I say, I thought it was a good idea at the time. I have also used 'brackets' in places, annoyingly so!
    I'm not sure if there is a fast and easy way of correcting these?; or if you have to deal with them CD by CD?
    Paul
      • 5778
      Hi GBrown,
      Paul
      1. dbpa Batch Converter, convert to "ID Tag Update" and use various options to replace names
      2. PerfectTunes
      3. mp3tag 'actions' to do the same basic thing as item 1 above. This can also get very fancy and strip out all " and ' etc. but I've not used that function and requires a bit of regedit formulation....
        • 4020
        If your sort tags contain non-alphabetic characters, this should not be a problem unless you have tags like:
        Corea, "Chuck" and Corea, Chick
        where you expect the sort order (ascending) to be:
        Corea, Chick
        Corea, "Chuck"
        because, it will probably be:
        Corea, "Chuck"
        Corea, Chick
        • monsterjazzlick
          • 1764
          Garym/Mville,
          Cheers guys, I'll respond over the weekend...
          Paul
          • monsterjazzlick
            • 1764
            2. PerfectTunes
            Hi Garym,
            Are these are 3 different methods for achieving the same end result? Or 3 individual steps which make up a single process?
            Cheers,
            Paul
            • monsterjazzlick
              • 1764
              Corea, "Chick"
              Mville
              Yes, this is Chick Corea's SORT tag.
              Paul
                • 5778
                Hi Garym,
                Cheers,
                Paul
                three different options for the same thing. Do only one of them.
                • monsterjazzlick
                  • 1764
                  Many thanks. I'll test later...
                    • 4020
                    Yes, I know, but it is only a problem if you ever have the situation as described in post no. 768, which is unlikely.
                    • monsterjazzlick
                      • 1764
                      Hi Garym,
                      I am quite unsure as to how to proceed, I am afraid. I guess I must have the wrong option selected? (please see attach.)
                      Paul
                        • 5778
                        Hi Garym,
                        Paul
                        https://drive.google.com/file/d/1CSs...ew?usp=sharing
                        it's denying access to google drive?
                        • monsterjazzlick
                          • 1764
                          Sorry about that, Garym.
                          There should be no limitations now:
                            • 5778
                            Looks like you are converting to FLAC and using ID TAG UPDATE DSP as part of FLAC conversion. That's not what you want to do. If you want to delete tags, you CONVERT to "ID TAG UPDATE" DSP, not FLAC. Then within the conversion popup box you can delete tags, etc.
                            • monsterjazzlick
                              • 1764
                              Thank you Garym, I'll sort it tomorrow...
                              • monsterjazzlick
                                • 1764
                                Hi Garym,
                                I have spent a couple of days now messin' around tryin' to follow your steps but I am afraid I am just totally dumb here and can'grasp it at all!
                                In the first instance, do I need to be on THIS page, please:
                                Sorry to be such a complete lame brain again!
                                Cheers.
