Tags, Tags, and more Tags ...
  • monsterjazzlick
    • 1764
    New folks at this forum, just starting the ripping journey, think the hard part is the actual bit perfect ripping. Turns out that's the mechanical part. Metadata....that's the hard part.
    Garym,
    You can include ME in that statement!
    Paul
    • monsterjazzlick
      • 1764
      Originally posted by GaryG45
      I think most of us have inconsistencies that we find and correct for the tags we are using. For the tags that you want to delete as long as you aren't displaying or using them, you won't see them so do the inconsistencies matter? My concern is if in the future you want to start using one of the sort tags again, you'll just have to correct the inconsistencies and not reenter the data for all of your files. I can also understand your desire to get rid of what you're not using. Just remember to have one or two backups before you start the deletions.
      Gary,
      It is reassuring to hear that other folk have experienced similar gripes to myself.
      The thought of "reentering" SORT data at a later stage is simply out of the question!
      Paul
      • monsterjazzlick
        • 1764
        Originally posted by schmidj
        And, yes, no matter how careful I am, my metadata is riddled with errors and inconsistencies. Metadata is the bane of my life. Some day, after I get those last few hundred CDs reripped, I'll try using Perfectunes to clean it up.
        Hi schmidj,
        I am really surprised at how many typos I made because as far as I was aware I was being extremely methodical. However, as mentioned, some days I did 4 hours straight (which is not good on the eyes or concentration!).
        I can't even remember the last time I ran Perfectunes?!
        Paul
        • monsterjazzlick
          • 1764
          Here is a classic example of something I thought was a great idea at the time, but have come to live to regret it of recent!
          For artists who have a popular nickname I included it in inverted-commas. It's ended up, as you would expect (such as in the case of: "Chick" Corea; "Duke" Ellington; "Count" Basie), placing such artists outside of the alphabet's linear-order (ie. either at the top, or bottom, of the entire library list).
          In any event, one of my future, laborious, tasks is to remove these...
            • 5753
            I thought you were using SORT tags,
            • monsterjazzlick
              • 1764
              Hi Garym,
              Well YES ;-)
              But, call me an idiot!, as I used "Chick" Corea and "Duke" Ellington WITH quotation-marks in the SORT fields.
              Paul
                • 5753
                Hi Garym,
                Well YES ;-)
                Paul
                I don't personally use sort tags, but it seems you would put Corea, "Chick" and Ellington, "Duke" in your ALBUMARTISTSORT tag.
                • monsterjazzlick
                  • 1764
                  Hi Gary,
                  Please see (sorry it's blurry!) dodgey screen-grab. I am sure I have tagged Corea's name as per advised a couple of years ago?
                  PaulClick image for larger version
                    • 5753
                    Hi Gary,
                    Hmmm, your sort tags are correct. So it is not the tagging. It must be that your music server/player doesn't make use of these sort tags when listing your artists in alphabetical order.
                    • monsterjazzlick
                      • 1764
                      Hi Garym - I use 3 playback devices: Sony Walkman, Amazon Fire, and Windows 10 Dell laptop. The latter two via Foobar s/w.
                        • 4015
                        In which player are you having the sort issue?
                        If you are using foobar on the Amazon Fire and the Windows 10 laptop, check you have configured foobar correctly, i.e. to sort, using the the sort tags.
                          • 5753
                          Exactly, foobar2000 can certainly be setup to sort artists using your sort tags. I have no clue re: fire or walkman.
                          • GBrown
                            • Oct 2009
                            • 274
                            Hi Gary,
                            Paul[ATTACH=CONFIG]2863[/ATTACH]
                            I use the Sort tags for iTunes, and Foobar on my Android phone. Also for Android, GoneMad (GMMP) has implemented the use of sort tags now as well (all but for Title for now) and it works great.
                            I try to eliminate anything in the sort tags that is irrelevant. So I would simply show Corea, Chick and get rid of the quotes. Same for things like brackets, this makes it more consistent regardless of the tag to make sure they group together. It work for my library, currently around 25k songs.
                            And for the record, I too am pretty diligent with my tags, have been since I started ripping my CD library around 2002 or so. And yet there are still titles that pop up when I shuffle the deck that I need to go back and find. Doubt I'll ever really be done!
                            • monsterjazzlick
                              • 1764
                              There is a crappy Sony s/w Music Manager you can d/l to manage your music files, but it is awful and everyone complains about it! Hence I uninstalled it!
                              • monsterjazzlick
                                • 1764
                                I am having the SORT issues on all 3 players.
                                Foobar is installed on my PC and Amazon Fire.
                                With the Sony Walkman, I just copied everything (from my PC) onto an SD-card and whacked it in! The only way you can manipulate the files, or similar, is by d/l Sony's dreadful s/w - which nobody uses.
