Tags, Tags, and more Tags ...
  • monsterjazzlick
    • 1764
    #46
    I could just as easily have used the > character, but such standards did not exist when I set off on my tagging marathon, many moons ago.
    OK, I see, thanks.
    So you might say that '~' vs. '>' could be a matter of personal preference.
      • 4018
      #47
      It IS only a matter of personal preference (remember also, that the > is an illegal filename character, so it will need handling).
      • monsterjazzlick
        • 1764
        #48
        On the Santana/McLaughlin CD, track-one is half music and half announcement!:
        "Echoes Of Angels" / Introductions
        Do you class this as:
        Echoes Of Angels~Introductions
        Many thanks.
        • monsterjazzlick
          • 1764
          #49
          mville, Cheers. I am settling for '~'. Thanks.
          • Oggy
            • 697
            #50
            Thanks Oggy,
            I have just been trying out the '~' kind suggestion and I have to say that I am favouring this format.
            In Foobar, if I search for '~', then all of the 'medleys' appear!
            I think I also prefer the visual appearance. In the attached Santana/McLaughlin (PNG) track, I saved 15 x characters!
            [ATTACH=CONFIG]1753[/ATTACH]
            Cheers,
            Paul
            I have seen some names using the tilde character from one of the metadata providers; maybe they are rips entered by mville?! It is certainly a neat solution, and I like how you're using search to the max! Pleased that you've found a (legal) solution, that works well for you.
            Let's hope that Aphex Twin considers the illegal characters, if he ever gives us another, Computer Controlled Accoustic Instruments, album!!
            • Jailhouse
              • Sep 2016
              • 388
              #51
              He might have used those characters because they're illegal. He wouldn't the first.
              • monsterjazzlick
                • 1764
                #52
                Hope I am not being a pain by bumping my earlier question. Any help would be appreciated. Thanks a lot.
                • Oggy
                  • 697
                  #53
                  Ha! A work colleague got prison for importing an illegal character.
                  I like flirting with danger, so AC/DC remains!
                  • Oggy
                    • 697
                    #54
                    I thought you agreed with mville's suggestion, in post *49?
                    I forgot about the hash being replaced! This is exactly why the use of a legal character, such as the tilde, helps compatibility.
                    • monsterjazzlick
                      • 1764
                      #55
                      Hi Oggy,
                      Yes, I am using the '~' symbol for medley tracks.
                      But my question was rather would you use '~' when a single track consists of a song immediately followed by introductions/spoken material? I mean, it is not a medley because there is only one song!
                      eg. American Trilogy ~ Band Introductions
                      Really, the intros should have been placed on a separate track, rather than the tail end of another.
                      Cheers.
                      • Oggy
                        • 697
                        #56
                        Hi Oggy,
                        Cheers.
                        Yes, intros are often indexed incorrectly on CDs, so unless you split the track and re-index, in mville's words of wisdom, "it IS only a matter of personal preference".
                          • 4018
                          #57
                          When a single CD track contains more than 1 title, I use the tilde ~. I don't restrict it's use simply to medleys.
                          • monsterjazzlick
                            • 1764
                            #58
                            Oggy,
                            OK, cheers.
                            I will stick with:
                            for now. 'Splitting' the track might be something for the future.
                            Paul
                            • monsterjazzlick
                              • 1764
                              #59
                              mville,
                              OK great, thanks for clarifying.
                              Paul
                                • 4018
                                #60
                                You do realise that I work undercover for the tagging police!!
