Tags, Tags, and more Tags ...
  • monsterjazzlick
    • 1764
    Gee, here's ANOTHER one!:
    I am ripping the Mendelssohn CD:
    Actually, I knew this question was going to crop-up because I am aware I have quite a few CDs (mostly by Haydn) falling into this category.
    And so, many symphonies have an alternative/informal title (call it what you will):
    The Creation
    The London Symphony
    The Clock Symphony
    Do users include this nickname?; and if so, do they list it within parenthesis, inverted-commas, instead or as well as the official title? For example, in this particular scenario:
    Symphony No.3 (Scottish) in A Minor
    The Scottish Symphony, in A Minor
    Symphony No.3 in A Minor 'Scottish'
    In any event, my plan is to position the 'movement' and 'Op.' data directly after (so as to maintain consistency with all previous classicals):
    Symphony No.3 (Scottish) in A Minor: iii. Adagio (Op. 56)
    Many thanks,
    Paul
    • monsterjazzlick
      • 1764
      With respect the the same Mendelssohn CD, I am not sure how to list the Album-Title (and that of the parent-folder). For all of my previous classical rips, I have included - where one exists - the Opus No. For example:
      Holst; The Planets (Op.32); Suite De Ballet (Op.10)
      And so, for the Mendelssohn CD, would one use:
      Mendelssohn: Symphonies Nos. 3 & 4 (Op.56, Op.90); The Hebrides Overture (Op.26)
      Mendelssohn: Symphonies Nos. 3 (Op.56) & 4 (Op.90); The Hebrides Overture (Op.26)
      Mendelssohn: Symphonies Nos. 3 & 4; The Hebrides Overture (Op.56, Op. 90, Op.26)
      Mendelssohn: Symphonies Nos. 3 & 4; The Hebrides Overture (Op.56; Op. 90; Op.26)
      In the latter two, you can see ';' vs. ','.
      Thanks a lot.
      • Jailhouse
        • Sep 2016
        • 388
        That looks good to me if you add quotes to 'Scottish'.
        • Jailhouse
          • Sep 2016
          • 388
          [QUOTE=monsterjazzlick;183735]And so, for the Mendelssohn CD, would one use:
          QUOTE]
          I would choose the first example. It seems tidier to me.
          • Oggy
            • 697
            Hi Paul,
            Obviously can only answer for myself, but if a piece has a well known name, and particularly if it is on the cover, I use it:
            Symphony No. 3 in A minor, Op. 56 "Scottish"
            This seems to be the convention I've seen on covers, and apart from the fact that your cover has all first letters capitalised, is what Sony used.
            I remember "Fingal's Cave" from school, and surely everyone knows "Pastoral"
            • monsterjazzlick
              • 1764
              OK, cheers; will do.
              • monsterjazzlick
                • 1764
                Oggy,
                OK, I will include it then.
                However, I prefer the 'Op.' to always be at the end, and the informal name to be adjacent to the symphony no. And so, admittedly, I have broken convention with the latter.
                Secondly, I am not so sure if I like the use of quotation marks; I find such grammar can often look to busy on-the-eye. Though I do feel the informal name requires something; so for now, I have just used inverted-commas:
                Symphony No.3 ('Scottish') in A Minor: iii. Adagio (Op. 56)
                Paul
                • monsterjazzlick
                  • 1764
                  ... btw - Windoze does not like quotation-marks.
                  • Jailhouse
                    • Sep 2016
                    • 388
                    Double quotes (") are reserved for system use and cannot be used in file or folder names. Single quotes (') are okay.
                    Double quotes could be problematic in tags, depending on the player. I have at least one song title containing double quotes that foobar2000 handles without issue.
                    • monsterjazzlick
                      • 1764
                      Yes, the ("") show fine within foobar (I just tried it). But I would need to also test out such tagging on my Amazon Fire ...
                      • monsterjazzlick
                        • 1764
                        I am ripping the CD by Poulenc:
                        It features, on every track, the Artist (choir):
                        Choeur Régional Vittoria D'Ile De France
                        I wanted to check, please, is the CHORUS tag the correct field in which to state the CHOIR (eg. Coeur Régional Vittoria D'Ile De France)? And if so, there does not appear to be a CHORUS-SORT tag?
                        Cheers.
                        • Oggy
                          • 697
                          dBpoweramp can replace the " " with ' ' in the filenames (and all illegal Windows characters), but the " " show as expected in Foobar2000, Foobar mobile, Synology DS Audio and LMS (Logitech Media Server).
                          Folder names have the replaced characters, but the tags work fine in all the apps above: it would be good to know which, if any, apps do have problems?
                          Crisis¿ What Crisis¿
                          • Oggy
                            • 697
                            Cheers.
                            Hi Paul,
                            I guess you could use a custom Choir tag, but not sure if you would need an equivalent sort tag.
                              • 4016
                              Yes.
                              Correct, there is NO corresponding sort tag, for chorus.
                              • monsterjazzlick
                                • 1764
                                Mville,
                                Thanks a lot. I will use the CHORUS tag and just forget about any kind of related SORT.
