Tags, Tags, and more Tags ...
  • monsterjazzlick
    • 1764
    I'm not sure about PRODUCER, LABEL, VENUE. But I'd guess they do NOT handle multiple values. So you'd be back to using "," or "/".
    I have totally killed off COMPOSER_SORT now.
    And am in the process of losing the '/' symbol - within VENUE and PRODUCER fields - in favour of a ',' (please see "Heavy Heart" - Carla Bley / "Master Strokes" - Bill Bruford):
    Cheers,
    Paul
    • monsterjazzlick
      • 1764
      I am editing an album (a compilation called "Stan Getz & Colleagues") which has (for one track) a rather long medley!:
      I have re-tagged the COMPOSERS properly (ie. with a ',' instead of '/'), but I am not sure which symbol I should use for the actual SONGS, please? As you can see, at the moment, they are still '/'.
      I would think the decision as to whether or not to tag as individual songs, or as a medley in it's own right, would depend upon if the user wanted the songs to show up - when running a search - as a whole, or as separate titles.
      This is the first time I have come across a 'medley' as yet.
      Many thanks in advance,
      Paul
      • Oggy
        • 697
        I am editing an album which has (for one track) a rather long medley:
        [ATTACH=CONFIG]1750[/ATTACH]
        I have re-tagged the COMPOSERS properly (ie. with a ',' instead of '/'), but I am not sure which symbol I should used for the actual SONGS, please? As you can see, at the moment, they are still '/'.
        I would think the decision as to whether or not to tag it as individual songs or as a medley in it's own right would depend upon if the user wanted the songs to show up - when running a search - as a whole, or as separate titles.
        Paul
        Paul, I use / for medleys. Because of the forbidden Windows filename characters, this will show as - on Windows devices.
        • monsterjazzlick
          • 1764
          Hi Oggy,
          Thanks for the fast response!
          Oh really? So no ',' or ';'! I should just leave it exactly as it is then?
          If you look at the very top field in the screenshot, then you will see a '-' separator, which I think is what you are specifically referring to?
          Cheers,
          Paul
            • 5769
            Hi Oggy,
            Cheers,
            Paul
            definitely NOT a semicolon. I use / or sometimes >
            • monsterjazzlick
              • 1764
              #21
              Hi Gary,
              Thanks for clarifying.
              Does the '>' appear as a '>', please? And is this - for yourself - just more of a visual (aesthetic) preference to a '/', or does it have a specific function, please?
              Cheers,
              Paul
                • 5769
                #22
                Hi Gary,
                Cheers,
                Paul
                nothing special. I tend to use the ">" in live shows where one song blends into another. This has long been a common indicator of this by collectors of live "bootleg" shows. I use "/" on studio albums where there is a medley.
                • monsterjazzlick
                  • 1764
                  #23
                  Thanks for the insight Gary.
                  I think I will stick with the '/' as I have a lot on my plate as it is! I can always go back and change such symbols at a later date, if need be.
                  Cheers,
                  Paul
                  • monsterjazzlick
                    • 1764
                    #24
                    I am tagging an album in which Chick Corea is playing and being interviewed by Marian McPartland.
                    The format is basically:
                    1 - Interview
                    2 - Song
                    3 - Interview
                    4 - Song
                    and so on ...
                    Obviously the songs take care of themselves. But with the interviews, what do you place in COMPOSER? I would guess that the two options would be to state:
                    'Chick Corea; Marian McPartland'
                    or to state:
                    'N/A' (non applicable)
                    Many thanks,
                    Paul
                    EDIT: Click image for larger version
                      • 5769
                      #25
                      1 - Interview
                      2 - Song
                      3 - Interview
                      4 - Song
                      and so on ...
                      or to state:
                      Many thanks,
                      Paul
                      If its not a song, I'd leave the COMPOSER tag blank.
                        • 4018
                        #26
                        Be careful. I have always tried to avoid using semi-colon and forward slash characters in my tags (unless as a separator), as tag editing software use these characters as separators in multi-value tags.
                        Historically, there have always been issues with users using AC/DC in the artist and album artist tags.
                        • monsterjazzlick
                          • 1764
                          #27
                          Gary,
                          Would you just leave it empty, or would you check the red-cross and DELETE the field completely, please?
                          Or it is the same difference?
                          Paul
                          • Oggy
                            • 697
                            #28
                            I've never seen a > used, with the exception of, <segue> between two tracks from a 24/96 FLAC file. On both the LP and CD, these are listed as separate tracks, but the music is continuous, I changed it to /
                            If you look at the track names from the metadata providers, most use / or - some have a space, on the LHS, some on the RHS, the rest a space either side - I use the latter.
                            I really like the idea of using the > !
                            This is all personal preference, as you can rename a song title, to anything you want.
                            Choices!!
                              • 4018
                              #29
                              but with the interviews, what do you place in composer? I would guess that the two options would be to state:
                              'chick corea; marian mcpartland'
                              or to state:
                              'n/a' (non applicable)
                              FWIW, when a composer is unknown, I use unknown, for dialog, interviews etc. I use n\a.
                              For medleys (in the title) I use ~.
                              • monsterjazzlick
                                • 1764
                                #30
                                Be careful. I have always tried to avoid using semi-colon and forward slash characters in my tags, as tag editing software use these characters as separators in multi-value tags. Historically, there have always been issues with users using AC/DC in the artist and album artist tags.
                                Thanks mville,
                                Do you mean if/when you open/edit your FLACs in a s/w other than Illustrate?
                                Paul
