Tags, Tags, and more Tags ...
  • evasv
    • Jan 2016
    • 114
    That looks ok (but you are missing some studios which you probably are aware of).
    Maybe replacing "or" with "??" for better readability?
    Abbey Road Studios, London ?? Avatar Studios, New York ?? Bennett Studios, New Jersey ?? Ben's Studio, Nashville ?? ...
    But to be honest, that's an awful lot of studios in one tag. With so many uncertain entries, you'll get many inaccurate search results.
    Personally, I'd settle for "Unknown" until I could verify the studios. Your choice though.
      • 5779
      Will you ever be searching on studio name? There's lots of stuff you may want to know about an album/recording. In some cases (particularly lots of unreleased live shows I have), I simply have a *.txt file that is saved in the same subdirectory of the album audio tracks. This txt file has information about the show, guest artists, venue info, info on who recorded it, etc. I can't search in my player on info in the txt file, but if I want to know something about the album, I can open this and read it. See for example,
      • Jailhouse
        • Sep 2016
        • 388
        All those possible studios, but no definitive information; it could be any of them, or none. If you really feel the need to list them all in a tag, you might want to use "Unknown" as suggested by evasv and list the studios in parentheses, prepended with "Possible:" or "Possibly" or something similar. And maybe use the pipe character to separate them. Like so...
        Unknown (Possible: Abbey Road Studios, London | Avatar Studios, New York | Bennett Studios, New Jersey | Ben's Studio, Nashville)
        This way, you can see immediately that whatever information is there is only speculation.
        • monsterjazzlick
          • 1764
          https://ia902309.us.archive.org/35/i...MatrixInfo.txt
          Hi Gary,
          Well for most of my 'artists;' the studio/location is something I am very interested in.
          As I said a few months back, I do miss the sleeve-notes and LP covers which you could read like a book! So your *.txt file idea is excellent. But I don't think I would have the time and energy to compile such docs for my library; as I would like to have this *.txt file for ALL CDs. I am aged 50 next year; but if I was (say) 20, then I would definitely have created these because I would probably have another 50 years listening left!
          Cheers,
          Paul
          • monsterjazzlick
            • 1764
            Evasv,
            Yes, I agree it's a lot of info in a single tag!
            I would prefer to not use the "??" if possible, thanks.
            I will consider the "unknown" option if I am not able to arrive at something more suitable.
            Cheers,
            Paul
            • monsterjazzlick
              • 1764
              Thanks JH,
              I think your suggestion is the closest to what I am looking for as an all time solution, thanks.
              How about if I tweaked it and made it:
              Possibly: Abbey Road Studios, London / Avatar Studios, New York / Bennett Studios, New Jersey / Ben's Studio, Nashville
              I have used the '/' instead of the pipe throughout my VENUE/LOCATION and RECORD-LABEL tags.
              Paul
              • monsterjazzlick
                • 1764
                Hi JH,
                I have abbreviated the US states in the Tony Bennett VENUE tag:
                Unknown (Possible: Abbey Road Studios, London / Avatar Studios, NY / Bennett Studios, NJ / Ben's Studio, TN / Capitol Studios, CA / Henson Recording Studios, CA)
                Paul
                • Jailhouse
                  • Sep 2016
                  • 388
                  Looks good to me.
                  • Jailhouse
                    • Sep 2016
                    • 388
                    Even better!
                    • monsterjazzlick
                      • 1764
                      Looks good to me.
                      Cheers JH.
                      • evasv
                        • Jan 2016
                        • 114
                        I think Jailhouse's idea is a great solution for you, since you want to tag unverified data. If you want to update/verify the tags later on, you can search for "Unknown" to have a list of candidates.
                        Your latest syntax with US states looks neater, but you won't be able to search for e.g. studios in Nashville (if required).
                        • monsterjazzlick
                          • 1764
                          Thanks evasv,
                          The Tony Bennett CD is not one which I am adamant about ultra-specifics; so the abbreviations are fine here. But if it was (say) a Miles Davis CD then I would list everything!
                          In any event, I doubt there will be many CDs which contain such a long tag in this respect. Hopefully not anyway!
                          Yes, I have taken JHs naming scheme in the end.
                          Cheers,
                          Paul
                          • monsterjazzlick
                            • 1764
                            I am ripping a CD which has one track by the:
                            Melody Maker's Competition Band
                            But I am not sure what would be the best ARTIST SORT here, please?
                            Many thanks,
                            Paul
                              • 5779
                              Many thanks,
                              Paul
                              I'd use:
                              Keep in mind that artist sort is simply to make it show up in any list in your music library in the right place in alphabet. and for this, I'd want it in the "M" category.
                              (you woudn't use "Stones, The Rolling" as an artist sort. You might use, "Rolling Stones, The". I don't have to worry about "the" as my library automatically ignores "The" and would put "The Rolling Stones" in "R".
                              You wouldn't use, "Floyd, Pink" as sort for "Pink Floyd". You'd want Pink Floyd to sort under "P".
                              • monsterjazzlick
                                • 1764
                                I'd use:
                                Thanks Gary,
                                That's great.
                                Someone else said to think of it as how you would like to see the ALBUM ARTIST catalogued (in the shelves) in a record store; which is also quite a good formula.
                                I do still get confused now and again though with certain band-names, as you can see.
                                Cheers,
                                Paul
