CD Ripper won't rip
    • 46198
    Re: CD Ripper won't rip
    Check have no DSP effects active.
    If still no go, try disable any security software you have.
    If still not work Uninstall dBpoweramp. Full restart of Windows, then reinstall.
    • Papajohn60
      • Nov 2017
      • 12
      Originally posted by Papajohn60
      Guys, just upgraded to 16.3 from 13.5. Cd Ripper will not rip my cd's. I've tried 5 different cd's to no avail. It says it does but when you look at the folder, it doesn't have file extension and nothing recognizes the file. I've tried everything, reinstalled several times. Nothing. Won't rip in mp3 or Flac. I'm running Win 10 64. I uninstalled 16.3 and reinstalled 13.5 and everything works like it used to. Any help on this would be greatly appreciated for I love this program and have used it for hundreds of cd's.
      John
      Ok here's the latest. I found a 15.3 trial version. Installed it and everything worked great. Upgraded to 16.3 and still can not rip or convert to Flac. I am seeing a temp file now when I got to rip or convert. Rename it, but it still doesn't work. Everything pertaining to Flac shows 0 bytes.
        • 46198
        Does the temp file grow in size? (right click >> Properties)
        • Papajohn60
          • Nov 2017
          • 12
          Only got it the 1 time. The flac file is always 0
            • 46198
            Try to disable your security software.
            • Papajohn60
              • Nov 2017
              • 12
              #21
              I'll try that in just a few before I go outside and get decorations. It is a beta of my virus software that I just installed prior to getting the update on dbpoweramp
              • Papajohn60
                • Nov 2017
                • 12
                #22
                I just disabled Webroot Beta, uninstalled db poweramp. Restarted windows and reloaded db power amp. No go....uninstalled Webroot beta, uninstalled db poweramp, restarted windows and reloaded db power amp. Same thing, not ripping to Flac (0bytes). I do not have any dsp effects active. I'm really at a loss as to what else to try. Especially since 13 and 15 work on here but not 16.3 I know it's something simple, but I'm at a loss.
                Thanks for all your patience!
                John
                  • 46198
                  #23
                  In dBpoweramp Control Centre >> Advanced Settings
                  Enable the debug log, then start CD Ripper, try to rip the disc to flac, then close cd ripper. A debug log will show, post the contents here please.
                  • Papajohn60
                    • Nov 2017
                    • 12
                    #24
                    Splitting Command Line:"C:\Program Files\dBpoweramp\CoreConverter.exe" -dbcmd="C:\Users\papaj\AppData\Local\Temp\dBT95EB.t mp"
                    ->-> [dBCoreConverter::ReaddBCommandFile]
                    <-<- [dBCoreConverter::ReaddBCommandFile]
                    Allying to Processor 1
                    ->-> [cldBCodecHandler::LoadEncoder]
                    Loading Encoder 'C:\Program Files\dBpoweramp\encoder\FLAC.DLL'
                    <-<- [cldBCodecHandler::LoadEncoder]
                    BatchID [clEncoder::Set]
                    ->-> [dBCoreConverter::StripCoreConverterCmds]
                    <-<- [dBCoreConverter::StripCoreConverterCmds]
                    SendRawUnCompressed [clEncoder::Get]
                    Communicate [clEncoder::Get]
                    ->-> [dBCoreConverter::OpenDecoder]
                    Reading StdIn Tmp File IDTags: Read
                    Using StdInput WFX:Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
                    <-<- [dBCoreConverter::OpenDecoder]
                    SendOverReplayGainTags [clEncoder::Get]
                    ->-> [clEncoder::BeginConversion]
                    Converting to 'C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\09 Dire Straits - Money For Nothing.flac' encoder settings ' -compression-level-6'
                    FLAC Compression Level: 6
                    <-<- [clEncoder::BeginConversion]
                    Encoding To: FLAC
                    Encoder Cmd Line: -compression-level-6
                    • Papajohn60
                      • Nov 2017
                      • 12
                      #25
                      Using SCSI PassThrough [clCDDA::SetCommunication]
                      ->-> [frmMain::RefreshTrackListing]
                      Quitting Meta Thread: Quit
                      ->-> [clCDDA::ReturnDriveList]
                      Got drive C:\ ** not CD Rom, type: 3 [cddaSCSIPassTru::FillDriveList]
                      Got drive D:\ ** not CD Rom, type: 3 [cddaSCSIPassTru::FillDriveList]
                      Got drive E:\ CD ROM [cddaSCSIPassTru::FillDriveList]
                      Got drive F:\ ** not CD Rom, type: 3 [cddaSCSIPassTru::FillDriveList]
                      Got drive G:\ CD ROM [cddaSCSIPassTru::FillDriveList]
                      Got drive H:\ ** not CD Rom, type: 3 [cddaSCSIPassTru::FillDriveList]
                      Got drive I:\ ** not CD Rom, type: 2 [cddaSCSIPassTru::FillDriveList]
                      <-<- [clCDDA::ReturnDriveList]
                      ->-> [clCDDA::ReadTOC]
                      LBA FirstIndex: 1 last Index: 16
                      Type: Audio Track 1 LBA Address: 0 Length: 00:05:50.400
                      Type: Audio Track 2 LBA Address: 26280 Length: 00:03:49.026
                      Type: Audio Track 3 LBA Address: 43457 Length: 00:06:05.000
                      Type: Audio Track 4 LBA Address: 70832 Length: 00:08:14.534
                      Type: Audio Track 5 LBA Address: 107922 Length: 00:05:54.440
                      Type: Audio Track 6 LBA Address: 134505 Length: 00:03:36.066
                      Type: Audio Track 7 LBA Address: 150710 Length: 00:03:40.760
                      Type: Audio Track 8 LBA Address: 167267 Length: 00:04:03.467
                      Type: Audio Track 9 LBA Address: 185527 Length: 00:04:09.707
                      Type: Audio Track 10 LBA Address: 204255 Length: 00:04:55.093
                      Type: Audio Track 11 LBA Address: 226387 Length: 00:04:12.467
                      Type: Audio Track 12 LBA Address: 245322 Length: 00:04:41.573
                      Type: Audio Track 13 LBA Address: 266440 Length: 00:05:01.760
                      Type: Audio Track 14 LBA Address: 289072 Length: 00:04:39.200
                      Type: Audio Track 15 LBA Address: 310012 Length: 00:05:41.640
                      Type: Audio Track 16 LBA Address: 335635 Length: 00:04:24.027
                      Type: Lead Out LBA Address: 355437
                      MSF FirstIndex: 1 last Index: 16
                      Type: Audio Track 1 MSF: 0/2/0 Length: 00:05:50.400
                      Type: Audio Track 2 MSF: 5/52/30 Length: 00:03:49.026
                      Type: Audio Track 3 MSF: 9/41/32 Length: 00:06:05.000
                      Type: Audio Track 4 MSF: 15/46/32 Length: 00:08:14.534
                      Type: Audio Track 5 MSF: 24/0/72 Length: 00:05:54.440
                      Type: Audio Track 6 MSF: 29/55/30 Length: 00:03:36.066
                      Type: Audio Track 7 MSF: 33/31/35 Length: 00:03:40.760
                      Type: Audio Track 8 MSF: 37/12/17 Length: 00:04:03.467
                      Type: Audio Track 9 MSF: 41/15/52 Length: 00:04:09.707
                      Type: Audio Track 10 MSF: 45/25/30 Length: 00:04:55.093
                      Type: Audio Track 11 MSF: 50/20/37 Length: 00:04:12.467
                      Type: Audio Track 12 MSF: 54/32/72 Length: 00:04:41.573
                      Type: Audio Track 13 MSF: 59/14/40 Length: 00:05:01.760
                      Type: Audio Track 14 MSF: 64/16/22 Length: 00:04:39.200
                      Type: Audio Track 15 MSF: 68/55/37 Length: 00:05:41.640
                      Type: Audio Track 16 MSF: 74/37/10 Length: 00:04:24.027
                      Type: Lead Out MSF: 79/1/12
                      <-<- [clCDDA::ReadTOC]
                      ->-> [frmMain::GetMeta]
                      ->-> [clMetaData::GetMetaData]
                      ->-> [clMetadBCache::GetMetaData]
                      <-<- [clMetadBCache::GetMetaData]
                      <-<- [clMetaData::GetMetaData]
                      ->-> [frmMain::MetaDataGot]
                      Meta Final Pass
                      <-<- [frmMain::MetaDataGot]
                      <-<- [frmMain::GetMeta]
                      <-<- [frmMain::RefreshTrackListing]
                      dBpoweramp Release 16.3 Digital Audio Extraction Log from Sunday, November 26, 2017 17:24
                      Drive & Settings
                      Ripping with drive 'G: [ASUS - DRW-24B1ST c ]', Drive offset: 6, Overread Lead-in/out: Yes
                      Encoder: FLAC -compression-level-6
                      Extraction Log
                      Ripping Method: Secure
                      ->-> [clRipperSecure::Init]
                      Type: Audio Track 0 LBA Address: 0 Length: 00:00:00.000
                      Type: Audio Track 0 LBA Address: 0 Length: 03:53:04.426
                      ->-> [clCDDA::SetDriveSpeed]
                      <-<- [clCDDA::SetDriveSpeed]
                      <-<- [clRipperSecure::Init]
                      ->-> [clRipperSecure::MoveOntoNextStage]
                      <-<- [clRipperSecure::MoveOntoNextStage]
                      Rip Exit By: MoveOntoNextStage
                      *** Information: Track 9: Ripped LBA 185527 to 204255 (4:09) in 0:18. Filename: C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\09 Dire Straits - Money For Nothing.flac
                      *** Information: AccurateRip: Accurate (confidence 200) [Pass 1]
                      *** Information: CRC32: 1E001E93 AccurateRip CRC: 72765C1D [DiscID: 016-002f97d4-023371dd-d8128310-9]
                      *** Information: AccurateRip Verified Confidence 200 [CRCv2 72765c1d], Using Pressing Offset -687
                      *** Information: AccurateRip Verified Confidence 200 [CRCv1 3860efc5], Using Pressing Offset -687
                      *** Information: AccurateRip Verified Confidence 159 [CRCv2 90d7e5cd], Using Pressing Offset -803
                      *** Information: AccurateRip Verified Confidence 130 [CRCv1 51df2eb2], Using Pressing Offset -803
                      ->-> [clCDDA::Destroy]
                      <-<- [clCDDA::Destroy]
                      *** Information: Track 10: Ripped LBA 204255 to 226387 (4:55) in 0:20. Filename: C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\10 Dire Straits - Brothers In Arms.flac
                      *** Information: CRC32: 728015F6 AccurateRip CRC: 712F18E0 [DiscID: 016-002f97d4-023371dd-d8128310-10]
                      *** Information: AccurateRip Verified Confidence 200 [CRCv2 712f18e0], Using Pressing Offset -687
                      *** Information: AccurateRip Verified Confidence 200 [CRCv1 206e8202], Using Pressing Offset -687
                      *** Information: AccurateRip Verified Confidence 158 [CRCv2 18d6d3fa], Using Pressing Offset -803
                      *** Information: AccurateRip Verified Confidence 131 [CRCv1 bbac31c0], Using Pressing Offset -803
                      ->-> [clCPUEncoder::WriteAccRipCRCTags]
                      Decodes [clDecoder::Get]
                      IDTags [clDecoder::Set]
                      ->-> [clDecoder::WriteIDTags]
                      Opening file 'C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\09 Dire Straits - Money For Nothing.flac' for write access: Opened
                      ->-> [clDecoder::Open]
                      Opening file 'C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\09 Dire Straits - Money For Nothing.flac' for read access: Opened
                      Init FLAC:
                      Reading Meta Data:
                      contained 0 tags:
                      ->-> [clDecoder::ReadIDTags]
                      <-<- [clDecoder::ReadIDTags]
                      <-<- [clDecoder::Open]
                      ->-> [clDecoder::Close]
                      <-<- [clDecoder::Close]
                      <-<- [clDecoder::WriteIDTags]
                      <-<- [clCPUEncoder::WriteAccRipCRCTags]
                      Opening file 'C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\10 Dire Straits - Brothers In Arms.flac' for write access: Opened
                      Opening file 'C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\10 Dire Straits - Brothers In Arms.flac' for read access: Opened
                      Init FLAC:
                      Reading Meta Data:
                      contained 0 tags:
                      2 Tracks Ripped Accurately
                      ->-> [clMetaData::SaveMetaData]
                      ->-> [clMetadBCache::SaveMetaData]
                      <-<- [clMetadBCache::SaveMetaData]
                      <-<- [clMetaData::SaveMetaData]
                        • 46198
                        #26
                        Try converting a Wave file to FLAC.
                        • Papajohn60
                          • Nov 2017
                          • 12
                          #27
                          Splitting Command Line:"C:\Program Files\dBpoweramp\CoreConverter.exe" -dbcmd="C:\Users\papaj\AppData\Local\Temp\dBTF96D.t mp"
                          Loading Encoder 'C:\Program Files\dBpoweramp\encoder\Wave.DLL'
                          BatchID [clEncoder_WAVE::Set]
                          SendRawUnCompressed [clEncoder_WAVE::Get]
                          Communicate [clEncoder_WAVE::Get]
                          SendOverReplayGainTags [clEncoder_WAVE::Get]
                          ->-> [clEncoder_WAVE::BeginConversion]
                          Converting to 'C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\07 Dire Straits - Love Over Gold (Live).wav.tmp.wav' encoder settings ' -compression="PCM"'
                          Wave output WaveFormat: Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
                          ->-> [clRIFFHandler::InitializeNewWAV]
                          clRIFFHandler::CalcAllChunks: Ok
                          ->-> Adding Chunk 'fmt ' Length: 16 [clRIFFHandler::AddChunk]
                          <-<- [clRIFFHandler::AddChunk]
                          ->-> Adding Chunk 'data' Length: 0 [clRIFFHandler::AddChunk]
                          ->-> [clRIFFHandler::WriteChunkHeaders]
                          Writing Chunk Header 'fmt ' Length: 16 ChunkPosition: 12 ChunkDataPos: 20
                          Writing Chunk Header 'data' Length: 0 ChunkPosition: 36 ChunkDataPos: 44
                          <-<- Exit as only write to data chunk [clRIFFHandler::WriteChunkHeaders]
                          Writing Chunk Data 'fmt ' Length: 16 ChunkPosition: 12 ChunkDataPos: 20
                          <-<- [clRIFFHandler::InitializeNewWAV]
                          <-<- [clEncoder_WAVE::BeginConversion]
                          Encoding To: Wave
                          Encoder Cmd Line: -compression="PCM"
                          ->-> [dBCoreConverter::CloseDecoder]
                          <-<- [dBCoreConverter::CloseDecoder]
                          ->-> [clEncoder_WAVE::EndConversion]
                          Writing Chunk Header 'data' Length: 38942064 ChunkPosition: 36 ChunkDataPos: 44
                          <-<- [clRIFFHandler::WriteChunkHeaders]
                          <-<- [clEncoder_WAVE::EndConversion]
                          File Size Check (before overwrite final): 38942108 bytes Filename: C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\07 Dire Straits - Love Over Gold (Live).wav.tmp.wav
                          File Size Check (before ID Tags Written): 38942108 bytes Filename: C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\07 Dire Straits - Love Over Gold (Live).wav
                          ->-> [dBCoreConverter::IDTagWriter]
                          Decodes [clDecoder_Wave::Get]
                          IDTags [clDecoder_Wave::Set]
                          ->-> [clWaveDecoder_Wave::WriteIDTags]
                          ->-> [clRIFFBEXTChunk::TagsToBEXT]
                          Encoding BEXT chunk [clRIFFBEXTChunk::TagsToBEXT]
                          <-<- [clRIFFBEXTChunk::TagsToBEXT]
                          Opening file 'C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\07 Dire Straits - Love Over Gold (Live).wav' for write access: Opened
                          ->-> [clRIFFHandler::Initialize]
                          <-<- [clRIFFHandler::Initialize]
                          ->-> [clRIFFHandler::ScanFile]
                          RIFF Header 'RIFF' Length: 38942100 FormType 'WAVE'
                          Got Chunk 'fmt ' Length: 16 RiffSizeLeft: 38942088 ChunkPosition: 12
                          Got Chunk 'data' Length: 38942064 RiffSizeLeft: 38942064 ChunkPosition: 36
                          <-<- [clRIFFHandler::ScanFile]
                          ->-> [clRIFFLISTChunk::TagsToLIST]
                          <-<- [clRIFFLISTChunk::TagsToLIST]
                          Writing Chunk Header 'LIST' Length: 252 ChunkPosition: 38942108 ChunkDataPos: 38942116
                          Writing Chunk Header 'id3 ' Length: 113866 ChunkPosition: 38942368 ChunkDataPos: 38942376
                          <-<- [clWaveDecoder_Wave::WriteIDTags]
                          <-<- [dBCoreConverter::IDTagWriter]
                          Conversion completed in 20.9 seconds x10 realtime encoding
                          File Size Check (core converter exit): 39056242 bytes Filename: C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\07 Dire Straits - Love Over Gold (Live).wav
                          • Papajohn60
                            • Nov 2017
                            • 12
                            #28
                            Splitting Command Line:"C:\Program Files\dBpoweramp\CoreConverter.exe" -dbcmd="C:\Users\papaj\AppData\Local\Temp\dBT1AEA.t mp"
                            BatchID [clDecoder_Wave::Set]
                            Communicate [clDecoder_Wave::Get]
                            NeedHQAudio [clEncoder::Get]
                            ->-> [clDecoder_Wave::Open]
                            Opening file 'C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\07 Dire Straits - Love Over Gold (Live).wav' for read access: Opened
                            Reading Audio Information
                            ->-> [clWaveDecoder_Wave::Initialize]
                            <-<- [clWaveDecoder_Wave::Initialize]
                            RIFF Header 'RIFF' Length: 39056378 FormType 'WAVE'
                            Got Chunk 'fmt ' Length: 16 RiffSizeLeft: 39056366 ChunkPosition: 12
                            Got Chunk 'data' Length: 38942064 RiffSizeLeft: 39056342 ChunkPosition: 36
                            Got Chunk 'LIST' Length: 252 RiffSizeLeft: 114270 ChunkPosition: 38942108
                            Got Chunk 'id3 ' Length: 114010 RiffSizeLeft: 114010 ChunkPosition: 38942368
                            Read Audio Information
                            ->-> [clWaveDecoder_Wave::ReadIDTags]
                            ->-> [clWaveDecoder_Wave::PullOutFMTnDATA]
                            Finding 'fmt ' chunk.
                            Finding 'data' chunk.
                            Assigning 'fmt ' chunk to WFX
                            <-<- [clWaveDecoder_Wave::PullOutFMTnDATA]
                            ->-> [clRIFFLISTChunk::InitFrom]
                            Found Correct INFO ID, decoding LIST chunk:
                            <-<- [clRIFFLISTChunk::InitFrom]
                            22 ID Tags:
                            AccurateRipDiscID: 016-002f97d4-023371dd-d8128310-7
                            AccurateRipResult: AccurateRip: Accurate (confidence 200) [8EEB17CA]
                            Album: Sultans Of Swing: The Very Best Of Dire Straits
                            Album Artist: Dire Straits
                            Catalog *: 9 47130-2
                            Composer: Mark Knopfler
                            Disc: 1/1
                            Encoded by: dBpoweramp Release 16.3
                            Encoder: Wave
                            Encoder Settings: -compression="PCM"
                            Genre: Rock
                            ISRC: GBF088490008
                            Label: Warner Bros.
                            Source: CD (Lossless)
                            Style: Classic Rock
                            Title: Love Over Gold (Live)
                            Track: 7/16
                            Year: 1998
                            _albumart_1_Front Album Cover: DATA Length: 113387 ......JFIF.....`.`..
                            _riff_1: DATA Length: 4 fmt
                            _riff_2: DATA Length: 4 data
                            <-<- [clWaveDecoder_Wave::ReadIDTags]
                            ->-> [clWaveDecoder_Wave::FillAudioProps]
                            Audio Quality: CD (Lossless)
                            Encoder Settings: PCM
                            Wave Header: Wave Format PCM
                            Channel Mapping: Left, Right
                            Sample Count: 9,735,516
                            Riff Chunks: 'fmt ' 16 bytes, 'data' 37.14 MB, 'LIST' 252 bytes, 'id3 ' 112 KB
                            ID Tag: LIST & ID3
                            Contains: Album Art, ID Tag[LIST & ID3]
                            Gapless: Yes
                            <-<- [clWaveDecoder_Wave::FillAudioProps]
                            Writing Audio Information
                            ->-> [clWaveDecoder_Wave::FillAudioInfo]
                            Audio Length: 220760 mili-seconds 38942064 bytes 1411 kbps
                            <-<- [clWaveDecoder_Wave::FillAudioInfo]
                            Written Audio Information
                            Preparing to Decode
                            ->-> [clWaveDecoder_Wave::PrepareToDecodeAudio]
                            Calling ACMDecoder.CreateNewConverter
                            Compressed WFX (on file): Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
                            Uncompressed WFX (sent to db): Format Tag: 1 Channels: 2 Bits per Sample: 16 Samples Per Second: 44100 Bytes Per Second: 176400 Block Align: 4 CB Size: 0
                            Setting Position in File
                            <-<- [clWaveDecoder_Wave::PrepareToDecodeAudio]
                            Prepared Decoding
                            <-<- [clDecoder_Wave::Open]
                            Converting to 'C:\Papa John's Music\Temp\Dire Straits\Sultans Of Swing; The Very Best Of Dire Straits\07 Dire Straits - Love Over Gold (Live).flac' encoder settings ' -compression-level-6'
                            Encoding To: FLAC
                            • Papajohn60
                              • Nov 2017
                              • 12
                              #29
                              No go here's the directory showing the wav and attempted Flac. Size is always the same.Click image for larger version
                                • 46198
                                #30
                                This is likely an issue inside the latest flac libs, I had heard reports of it breaking on specific CPU types. If you personal message me your order number, I can give out a R16.2 of dBpoweramp, which has 1.3.1 of FLAC.
