RE: Defining 'Compilation' (help?)
  • monsterjazzlick
    • 1764
    Re: Defining 'Compilation' (help?)
    I am ripping the compilation CD 'Stockhausen / Kurtág - Gruppen; Grabstein Für Stephan; Stele':
    So, one work by Stockhausen and two by Kurtag. I went through this thread but I could not see the answer to my predicament. It's quite a basic question actually but I have not, as yet, ripped a 'classical' compilation like this one.
    For ALBUMARTIST, would you use:
    For all tracks - ALBUM ARTIST = Stockhousen; Kurtag
    Or,
    Track 1 - ALBUMARTIST = Kurtag
    Track 2 - ALBUM ARTIST = Stockhousen
    Track 3 - ALBUM ARTIST = Kurtag
    Track 4 - ALBUM ARTIST = Kurtag
    Track 5 - ALBUM ARTIST = Kurtag
    Or, even something different?
    Obviously the 'compilation' box is checked.
    The reason I ask, please, is because - with 'classicals' - sometimes rules can change a bit, if you know what I mean. Every 'classical' CD (esp. opera - 'Tristan & Isolde' took DAYS!) is throwing up new issues and so I wanted to double-check here first before ripping.
    Many thanks,
    Paul
      • 4015
      Personally, I would keep ALBUM ARTIST consistent across all tracks of an album e.g.:
      ALBUM ARTIST = Various Artists
      OR
      ALBUM ARTIST = David Byrne; Brian Eno
      OR
      ALBUM ARTIST = Karlheinz Stockhausen; György Kurtág
      I foresee issues with player software and different Album Artists.
        • 5754
        OR
        OR
        agree. That's the point of the ALBUM ARTIST field. Use ARTIST to hold actual artist info, but ALBUM ARTIST should be a single entry for the entire album. And in my own naming string, if I used a differing ALBUM ARTIST entries, the tracks would all be filed under different subfolders (which would be bad organization for me).
        • monsterjazzlick
          • 1764
          OR
          OR
          OK, cheers.
          For such scenarios I have used:
          in all my other GENRES.
          But as I say, I have found with 'classicals' that you sometimes end up having to bend the rules slightly here and there.
          • monsterjazzlick
            • 1764
            Thanks a lot.
            I have noticed a couple of quirks here and there in my other rips (dating back to mid-last-year). I will check over them at some point as I dare say the issue is related to the points being discussed in this recent discussion. It's only with 2 or 3 albums, so not too colossal.
            • monsterjazzlick
              • 1764
              OR
              OR
              Just to double-check, while we are on the subject, do you also include an ALBUMARTISTSORT tag such as:
              ALBUMARTISTSORT = Various Artists
                • 4015
                Yes I do e.g.:
                ALBUM ARTIST SORT = Various Artists
                ALBUM ARTIST SORT = Byrne, David; Eno, Brian
                ALBUM ARTIST SORT = Stockhausen, Karlheinz; Kurtág, György
                ... also, when my album is a compilation, then ALBUM ARTIST is always Various Artists.
                Last edited by mville; November 05, 2018, 03:27 PM. Reason: added compilation info
                • monsterjazzlick
                  • 1764
                  Yes I do e.g.:
                  That's great. I will use it on my 'classicals' also now.
                  Cheers.
