RE: Defining 'Compilation' (help?)
  • monsterjazzlick
    • 1764
    #151
    Re: Defining 'Compilation' (help?)
    I am ripping the compilation CD 'Stockhausen / Kurtág - Gruppen; Grabstein Für Stephan; Stele':
    So, one work by Stockhausen and two by Kurtag. I went through this thread but I could not see the answer to my predicament. It's quite a basic question actually but I have not, as yet, ripped a 'classical' compilation like this one.
    For ALBUMARTIST, would you use:
    For all tracks - ALBUM ARTIST = Stockhousen; Kurtag
    Or,
    Track 1 - ALBUMARTIST = Kurtag
    Track 2 - ALBUM ARTIST = Stockhousen
    Track 3 - ALBUM ARTIST = Kurtag
    Track 4 - ALBUM ARTIST = Kurtag
    Track 5 - ALBUM ARTIST = Kurtag
    Or, even something different?
    Obviously the 'compilation' box is checked.
    The reason I ask, please, is because - with 'classicals' - sometimes rules can change a bit, if you know what I mean. Every 'classical' CD (esp. opera - 'Tristan & Isolde' took DAYS!) is throwing up new issues and so I wanted to double-check here first before ripping.
    Many thanks,
    Paul
      Personally, I would keep ALBUM ARTIST consistent across all tracks of an album e.g.:
      ALBUM ARTIST = Various Artists
      OR
      ALBUM ARTIST = David Byrne; Brian Eno
      OR
      ALBUM ARTIST = Karlheinz Stockhausen; György Kurtág
      I foresee issues with player software and different Album Artists.
        OR
        OR
        agree. That's the point of the ALBUM ARTIST field. Use ARTIST to hold actual artist info, but ALBUM ARTIST should be a single entry for the entire album. And in my own naming string, if I used a differing ALBUM ARTIST entries, the tracks would all be filed under different subfolders (which would be bad organization for me).
        • monsterjazzlick
          • 1764
          #154
          OR
          OR
          OK, cheers.
          For such scenarios I have used:
          in all my other GENRES.
          But as I say, I have found with 'classicals' that you sometimes end up having to bend the rules slightly here and there.
          • monsterjazzlick
            • 1764
            #155
            Thanks a lot.
            I have noticed a couple of quirks here and there in my other rips (dating back to mid-last-year). I will check over them at some point as I dare say the issue is related to the points being discussed in this recent discussion. It's only with 2 or 3 albums, so not too colossal.
            • monsterjazzlick
              • 1764
              #156
              OR
              OR
              Just to double-check, while we are on the subject, do you also include an ALBUMARTISTSORT tag such as:
              ALBUMARTISTSORT = Various Artists
                Yes I do e.g.:
                ALBUM ARTIST SORT = Various Artists
                ALBUM ARTIST SORT = Byrne, David; Eno, Brian
                ALBUM ARTIST SORT = Stockhausen, Karlheinz; Kurtág, György
                ... also, when my album is a compilation, then ALBUM ARTIST is always Various Artists.
                Last edited by mville; November 05, 2018, 03:27 PM. Reason: added compilation info
                • monsterjazzlick
                  • 1764
                  #158
                  Yes I do e.g.:
                  That's great. I will use it on my 'classicals' also now.
                  Cheers.
