  • Oggy
    • 702
    #121
    Sorted man!
    Works a treat.
    I have included screenshots of 'dBpa' and 'file properties' tags.
    But I can't get: 'Comments', 'Composer, or 'Producer' to show. Maybe the Sony just won't display these, period?
    Thanks a lot,
    Paul
    [ATTACH=CONFIG]1403[/ATTACH]
    [ATTACH=CONFIG]1404[/ATTACH]
    Excellent! If you have tracks with a featured artist, you will probably have to do the same again using the forward slash, rather than the semi-colon. The Beatles / Billy Preston. Alternatively some use, The Beatles Featuring Billy Preston.
    Judging by the display options you listed in the previous post, your Sony won't show any extra tags, but does use the important ones.
    Have you tried a double album and Compilation yet?
    • monsterjazzlick
      • 1764
      #122
      Hi Oggy,
      So like: 'Miles Davis Band featuring John Coltrane' = 'Miles Davis / John Coltrane'; or ''Miles Davis / feat. John Coltrane'.
      Shame it won't show 'Producer' or 'Label, nut it's not the end of the world.
      No, no double-albums or comps. yet; saving those for last!
      Cheers,
      Paul
      • Oggy
        • 702
        #123
        Hi Oggy,
        Cheers,
        Paul
        Yes, see how they display. Also how the Sony works with Artist and Album Artist.
        It is a shame a full tagging standard hasn't been agreed and ahem, sorted.
        Once you know how your player works, you can tag accordingly, sure you could do more than one a day!
        • monsterjazzlick
          • 1764
          #124
          Hi Oggy,
          Well if Sony do not get back to me with a solid resolution over this stupid 'EU' Law regarding the volume, I may have to get a refund; and so will consider an entirely different player altogether. But hopefully it won't get to that stage.
          But tagging-wise, I can probably live with it as it is.
          Paul
          • monsterjazzlick
            • 1764
            #125
            Sony have told me I need to 'reformat' the Walkman. Not sure how this will help the 'volume' issue though?
            Paul
            • Oggy
              • 702
              #126
              Paul
              Hi Paul,
              Some people have rescued their Sony player from the volume restriction, by reformatting and some software fix. Not sure what Sony say about warranty etc.
              Don't you just love EU directives.
              • monsterjazzlick
                • 1764
                #127
                Oggy,
                I am the most staunch Brexiter you ever met! Should never have gotten dragged into it in the first place.
                Now we have hairdryers and hoovers which can't blow or suck air for toffee.
                Let us finally raise the drawbridge on our precious island; of which thousands fought for in two World Wars!
                Paul
                • monsterjazzlick
                  • 1764
                  #128
                  Frustratingly, the 're-formatting' did zlich to help cure the Sony Walkman's Volume issue!
                  Paul
                  • monsterjazzlick
                    • 1764
                    #129
                    Hi again,
                    I received an email from 'dBpa' offering for me to d/l the latest s/w version. Apparently it was updated recently.
                    I am on version: '16.2' (please see screenshot) of which I purchased around ten days ago.
                    Many thanks.
                      • 6114
                      #130
                      Hi again,
                      Many thanks.
                      [ATTACH=CONFIG]1406[/ATTACH]
                      That's the latest. I had an email from dbpa talking about new versions too. But I already have latest as well.
                      • monsterjazzlick
                        • 1764
                        #131
                        Here is a reply I just received from the SONY COMMUNITY forum. Regarding 'file transfer' and 'meta-data', obviously I don't want to be using the likes of 'Grace Music' or 'Media Go' because I have subscribed to 'dBpa'! Thanks, Paul.
                        In regards to your first question about tags, it does appear that it is limited. I have been searching for what type of ID3 tags are supported and the only thing I can find is in the specifications: HERE. Therefore things like Label or Producer is not supported.
                        Music Searching Methods - All songs, Album, Artist, Genre, Release year, Composer, Playlists, Hi-Res, Recent transfers, Folder, SensMe Channels.
                        Using the Media Go software, you can automatically get this metadata from the use of 'Gracenote' Music ID. See HERE for more info.
                        Question Volume - Unfortunately, I am familiar with the EU law in regards to limiting the volume on personal audio devices. Sucks I know. One thing to note is to ensure that AVLS is off. See HERE.
                        However there are 'ways' to remove this EU limitation. See the following sites:
                        Googling should provide you more links.
                        Please note: I have not tried this myself, so I dont know. Also this forum or myself is not responsible if you choose to 'research' alternative ways in regards to removing this EU limitation cap.
                        • monsterjazzlick
                          • 1764
                          #132
                          Thanks for the confirmation Gary.
                          • monsterjazzlick
                            • 1764
                            #133
                            ... btw: here is a screenshot of the 'properties' of the file I have ripped as (to?) FLAC. I think everything looks OK as far as I can tell.
                              • 6114
                              #134
                              [ATTACH=CONFIG]1409[/ATTACH]
                              Looks good to me.
                              • monsterjazzlick
                                • 1764
                                #135
                                Looks good to me.
                                Thanks for the clarification, Gary.
                                No Oggy tonight?!
