Hi again, If I check the 'Length' box in the 'Tag ID Options' window (ie. so as to permit this particular tag to show on compatible devices):
... and then I call up the 'Create New Tag' on the bottom of the page (as per screenshot):
... there is no choice (in the pop-up scroll) for 'Length'!? I would have thought that all of the possible tags offered in the 'Tag ID Options' (first screenshot) would appear in the lower pop-up of 'Create New Tag'. Or do you just have to type in the ones which are missing, please? Thanks.
