Leave as is, all that means, is that the album has, more than one composer.
The tags look good, except the unnecessary, Disc 1!
Oggy,
OK, great; will do.
Yup, I agree. I want to kill off the 'Disc' numbers in the album titles. I don't like them anymore. I just posted a couple of Q.s regarding this in the: 'Set Up For Ripping' thread.
Cheers.Comment
Back to 'Composers' again (if you will), I have completed all of the different Composer fields for each respective track - no problem.
But, there is a field that is empty which is also called 'Composer' (directly above: 'View All tracks'). It defaults to Wayne Shorter (either because he is the first composer on the first track, or because of GD3/Discogs etc).
Now, I can DELETE Wayne Shorter and leave it empty (not sure if that would effect anything?). However, if I try to type something in (ie. the names of the three composers of this album: Shorter / Hancock / Williams), then it writes in (automatically): 'Shorter / Hancock / Williams' in each individual track field (suggesting that every track was a combined composition by all three composers!).
On page 1, the "Various Composer" text remains intact.
Muchas gracias!Comment
Yes, you are displaying the first track, and the Composer, is Wayne Shorter.Hi,
[ATTACH=CONFIG]1428[/ATTACH]
[ATTACH=CONFIG]1429[/ATTACH]
Muchas gracias!
If you filled in Shorter / Hancock / Williams, and then hit, To All, this would overwrite, your first screenshot, and the Composer for each track, becomes, Shorter / Hancock / Williams. Do you really want that, and not what you had originally?Comment
Oggy,Yes, you are displaying the first track, and the Composer, is Wayne Shorter.
OK, cheers.
You are correct about my intentions; I don't want: 'Shorter / Hancock / Williams' for every track (because it would be inaccurate).
So it's showing Wayne Shorter because he is the Composer of track-1? So, please, is it then possible to flick through the other tracks to see if Hancock and Williams appear (in that very same verbatim box for their own respective tracks)? - I am not sure how to flick through them (I did try via the player). Or would you not even worry about it?!
I will rip it and see how it comes out ...
Paul
NB. I was wondering if W.S. was showing as the Composer because the first track and title of the CD is 'Nefertiti' (ie. his own composition?).Last edited by monsterjazzlick; August 07, 2017, 10:40 PM.Comment
You can highlight, any track, in your example, track 1, and hence, Wayne Shorter, is displayed.Oggy,
OK, cheers.
Paul
Using View Track-Artists, as in your screen shot, is probably the easiest method of checking, and correcting.
All seems well in the first screen shot.Comment
Oggy,
I just checked on my Sony player and all the Composer tags read fine.
I still cant work out - sorry to wreck your head! - how/where to highlight any track on the page of the screenshot, please? I've clicked everywhere; well obviously not everywhere as the respective Composers would have changed!
PaulComment
Paul,Oggy,
OK, cheers.
Paul
I meant to say, you can check (highlight, doh!), in the View Track-Artists, and correct from there, if necessary.
Yes, the first track Composer, is displayed, as in your screen shot.Last edited by Oggy; August 08, 2017, 04:14 PM.Comment
I am about to rip a Miles Davis CD called "TUTU".
The COMPILATION box has been automatically checked even though this is not a compilation album!:
Is this due to there being inaccurate information on-the-web?, and do I just simply uncheck it, please?
Many thanks.Comment
If the artist tag contains different values across the CD, CDRipper automatically ticks the Compilation box.
This behaviour is very annoying, but Illustrate insist that if the artist is not consistent (i.e. is not the same for all tracks) then it is a compilation, something I do not agree with.Comment
I expect it is a compilation the majority of the time, and the reason why CD Ripper is programmed that way. The one exception (barring errors) I can think of offhand would be some tracks where the Artist field has "Feat. [another artist]" appended to the album artist's name.If the artist tag contains different values across the CD, CDRipper automatically ticks the Compilation box.
Just another reason why one should always closely check all metadata/tags with every rip.Comment
