How to add CD number at first position before track number ?
  • MichelT
    • Jun 2017
    Hello,
    I do not find in the option a way to display CD number before the track number.
    Let me explain.
    I want to rip an opera which is stored on 3 CDs.
    I want that all the files are located in the same directory.
    Fo CD 1, First track will be 01 01 Title....
    the second 01 02 .....
    For CD 2, 0201... then 0202....
    and so else..
    Is it possible to do that ?
    At current state, I manually rename tracks. It's boring.
    Best regards,
    Michel T
    Re: How to add CD number at first position before track number ?
    Add [disc] to the naming string (before [track])
    • MichelT
      • Jun 2017
      Hello,
      It works. I thank you very much. Nevertheless, I do not understand the option "pad disc number" to 2 digits. It looks like as if it is not taken into account.
      disc uses the disc number mentioned. It takes 2 digits if I only specify 2 digits (03 by sample) but only one if I write "3".
      Best regards,
      Michel T
        This option is for the ID Tags, not filename.
