Does ripping speed really effect quality?
  • Jason Redux
    • May 2017
    My drive will rip much higher but I have chosen to rip at 20 speed, when it is ripping it shows around 14 speed.
    Does ripping higher or lower effect the resulting quality of the audio file, can ripping too high miss information?
  • jultsu
    • Mar 2016
    • 58
    Re: Does ripping speed really effect quality?
    It can if you are reading in burst mode. Secure mode = no effect.
      • 6189
      no. in fact artificially capping the speed of ripping can potentially cause more problems. Best to let automatically choose speed.
      • schmidj
        • Nov 2013
        • 599
        It is probably a good idea to tell the secure mode of dBpoweramp to vary the speed during playback. If all the passes are at the same speed and the disc is bad, there is a good possibility that the drive will read the disc with exactly the same error each time. Less likely if it reads the disc at different speeds for each pass.
        • Jason Redux
          • May 2017
          I am ripping in burst mode
          • thexfile
            • Jul 2010
            • 177
            Change to Secure (Recover Errors) mode.
